- Joshua
- Oct 19, 2020
- 1
- 46
- 50
- Lexington KY
- Bronco
- Badlands
So far I’ve had a chance to drive my Badlands on Spas Creek in slade county Kentucky. Along with many miles on highway and inner city Lexington.
It easily took on spas creek. Ran 80% of it in first/second gear 4L. Mainly to save trans. No lockers engaged. Sway bar disconnected here and there to see it’s limits. Vehicle did everything with ease!
City traffic can be rough in a manual at times, which is to be expected nonetheless. 2.3L still has enough pep for aggressive traffic. Brakes are excellent for how heavy the Bronco is.
Highway, it has a good amount of power, wind and rolling hills impact mpg drastically. It is shaped like a rolling brick, so fuel economy is expected to be lower. Can be noisy, though not overbearing in a soft top when trying to speak with passengers
My question I have, if anyone can help. When cruising on the highway (65-75mph 2.2ish rpm’s) turbo is almost always bouncing around 1-5psi. When going up a decent grade, I drop to 5th to keep the engine cool and heads from warping. (5th gear 2.9ish rpm’s) Is it fround upon staying in 5th for an extended period of time? Or am I downshifting for no reason and should I keep it in 6th gear, and let the turbo spool up past 12psi or so?
