- Aug 4, 2021
- 8
- 922
- 1,402
- North GA / MT
- ‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
- Outer Banks
Good point! Judging by the time stamp, I'd assume his 2.7l is the first generation as well.Okay, I read post 1 and skipped to the end since:
No actual 6g Bronco orders, only reservations, had been placed in December of 2020 or even his update in January 2021. his issues (and if he had repeat issues with same vehicle) are/were NOT with a Bronco but an f-150.
You can't compare Granny Smith apples to Honey Crisp. I believe the admins should relabel this thread to ensure it does not mislead people that there were turbo issues long before the first turbo Bronco was delivered
Now, if the OP's Bronco 's turbos just crapped out at 40,000 miles that's different but I do not plan on reading through 9 pages to verify but I will stand corrected if that is the case.
If this is instead an oil discussion, Ford has a spec and do not use any oil that does not have that spec printed on the container - but you certainly can go above that spec - full synthetic rather than blend, for example - or buy the brand from the actual manufacturer of the base stock of nearly all synthetic motor oil "refined" in the US - Schaeffer
