Ford Performance Calibration 2.7L for 37’s speedo calibration?
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
Curious, anyone that has used the tuner to calibrate to 37" tires, what did it set the circumference to? I manually changed via Forscan to 2775 and it has been pretty spot on up to 80-90 mph.
WowPaul
Paul
Canada
2022 Bronco
RickyLakeisaMAN
Dan
Phoenix
Bronco | Huracan Performante
I just had the Ford Performance tune installed and they forgot to adjust the tire size. I did it myself. If anyone needs to know, if you're running BF Goodrich KO2 37X12.50R17LT, the revs/mile should be set to 569. If you just plug the tire size into the calculator without specifying the exact tire, it will give you 545 revs/mile.
RickyLakeisaMAN
Dan
Phoenix
An update on this. Even though 569 come straight from BF Goodrich, it is not accurate. After some GPS testing, the revs/mile should be around 585. I GPS tested a long stretch of road and set the cruise to 50 mph. It was spot on 95% of the time, and indicated 49 mph about 5% of the time. The true revs should probably be somewhere between 585 and 590, but I'm close enough. These are new tires. I'm guessing after 50k miles it could change.
