Ford Performance Calibration Tune for 2.7L Bronco's AVAILABLE NOW! - Lethal Performance
Glenjafett
Atlanta
2023 Bronco
Did anyone notice how much more boost the FP tune runs over stock? I’d imagine it’s only a couple pounds and not too much change in timing seeing how it’s a relatively small gain.
I want to say I would get spikes to 17 psi on stock. I've seen spikes to 20 psi on the tune. It certainly doesn't hold to the redline though.
Ksjrb03
Tx
F250
I don’t know the exact answer, but it is significant improvement in 1st and 2nd gear, where the stock tune is severely nurtured. That and the incredibly improved shifting is worth it alone for me.
LethalPerformance
LethalPerformance
Jared
South Florida
www.lethalperformance.com
ultimateone
Boston
23 BB Sas Carbon Gray
Dmk08
GA
Walk
You're asking that in the thread in which is selling the product?
Just get it installed by Ford and you will have the warranty for it.
Any ASE certified tech right? Doesnt have to be Ford.
ultimateone
Boston
Do Ford Performance calibrations have a warranty?
Ford Performance calibrations are unique because they come with their own Ford warranty. If the Ford Performance calibration causes an issue to your car within 3 years or 36,000 miles from new vehicle in-service, Ford pays to fix your car. If the performance calibration did not cause the issue, your base Ford warranty still applies. The kits need to be installed by an A.S.E. certified shop or Ford dealer. In Canada, Red Seal certified technicians also can install Ford Performance calibrations to maintain warranty eligibility.
Just me though, I would get it done by a local dealer just in case
Dmk08
GA
Walk
I trust independent shop technicians that I know way more than any dealer tech. I lived with a couple dealer techs when I was just out of college and man did they cut corners. Anything to get paid more flat rate hours.
Hunger&SharkTooth
TN
@LethalPerformance can you install the k&n cold air intake with the ford performance tune 2.7L? Does it need specific programming?
ultimateone
Boston
Makes sense when it's actual work but this is just something you plug in and press "tune 93" and vwallah, tune installed.
Dmk08
GA
Walk
Itll cost $40-50 bucks at my local guy for that 2 seconds vs hundreds at a dealer.
21BL2DR
JD
ohio
2021 BL 2dr, 2021 BB 4dr, 2022 BS 2dr, trifecta
I own two 2023 Badlands with the 2.7. Do I have to buy a separate tune for each one of them or can I use the same tune on both? @LethalPerformance if I have to buy two is there a discount in pricing?
LethalPerformance
LethalPerformance
Jared
South Florida
Each of the devices/tunes are VIN locked so yes, you would have to buy two separate kits.
As far as a discount for 2 goes, shoot us a message!
