ryridesmotox
Ryan
Murrieta, California
21 Bronco Black Diamond
I had mentioned this earlier, that this is a material (alloy) problem and/or a valve design problem. They probably changed the specification of the alloy and increased the strength of the underhead and valve head area.
I seriously doubt it's an engine management problem, this would lead more to burned valves than broken valves.
If it was a tuning/ecu issue I'd expect to see the spark plug straps and electrodes utterly melted. The ones that have been floating around here looks like the electrodes were battered but not melted. Which leads me to believe a valve issue. It's not hard to imagine a bad valve with a crack in the stem failing
Beach_Bum
Ken
St. Augustine, FL
4 engines…at what point do you buy a Jeep lol
A Jeep would never ever be a consideration for Drew. He is the only one that I know that has a semi-truck serve as his tow pig for his Broncos when he goes wheeling. At some point, he'll have to get a double-deck carrier to accommodate his Broncitis.
Snydermann
Tim
South East, PA
Samurai, VW Thing, MINI, smart, Astro Van
Valves designed on the edge of reliability without wide enough manufacturing tolerances. If your valves were made within tolerances, you're probably fine, but if they drifted out of the narrow tolerances, they will fail.
By changing the material and design they increased the manufacturing tolerances so that the valves made now will have a lower failure rate.
geoking
george
Huntsville,AL
2020 GT500 , 2020 F150, 1934, 1948, 1958 , 1966
Tim,
All we need to know is WHEN were the changes implemented ? .....and when did heads with the higher reliability valves make it into new build engines? My first bronco is due to be built next week. I don't want the old valves....smile.
VictoryLights
Pittsburgh
2018 Honda Pilot
I think a lot of us could live with this explanation if we knew the failure rate on the delivered vehicles.
navi
Navi
CA
73 Bronco
Remember, it is what it is, don't live in fear, drive it like ya stole it, it's under warranty, ya'll a bunch of fishwives,
and I aint no fanboy!
navi
Navi
CA
73 Bronco
He must be driving the shit out of them with zero break in then. There's a better chance of winning the lottery than blowing 3 engines in a row that have a (very roughly) 0.5% failure rate.
VictoryLights
Pittsburgh
2018 Honda Pilot
I feel that.
However, this is an “adventure vehicle” designed and heavily marketed (“Built Wild”) to be something that takes you deep into the wilderness. How much would it cost to have one of these towed from the middle of black bear pass?
Snydermann
Tim
South East, PA
I understand.
The failure rate isn't 100%, so there is no way to know how well you can or can't sleep at night. I suspect once the engine is cycled past it's failure range the surviving engines will be okay.
VictoryLights
Pittsburgh
2018 Honda Pilot
I understand.
Are you speculating about this manufacturing tolerance or do you have some inside info?
JPye
Alberta canada
2012 BMW X5
I feel that.
Let's hope this is cleared up before someone goes full Donner Party in the wilderness.
Yodi
Tennessee
Mustang
I still think that if you want to get Fords attention, the people that have blown engines need to report to the NHTSA as a safety issue. I also think it is just a matter of time till this causes a serious wreck. Going down the highway at 70 and you find yourself without power brakes or steering is a bad thing!
VictoryLights
Pittsburgh
2018 Honda Pilot
You lose brakes and steering when this happens?
