tritonx100
2020 ford explore
that looks like a separate entry
Jimmy
Fronty/ FiST/ Z
I see various ring and pinion kits in accessories, but no locking rear differential option on the base. Only with Sasquatch Pkg.
Is this true?
Sampsonrustic
Sampson
SoCal
F150 4x4
It says all series include electronically locking front and rear axles. I'm assuming this is just standard 4x4, not lockers right? Also says push button start and keyless entry included on base! I don't know why but i thought i read that was only available on higher trims... One more happy camper here!
5280Bronco
Denver
Am I reading this right that you can order Base and Big Bend with the advanced 4x4 transfer case, it looks like you can. Yayy.
I looked at it more closely, and unlike BD where the sasquach pkg shows ot is Optional with the auto and the adv xfer case, the BB and base show Mandatory of you choose the auto and the adv xfer case, so it seems to support the previous situation that you need to go squach on base or BB to get the adv xfer case. Looks like I'm sticking with BD.
Jimmy
Fronty/ FiST/ Z
Isn't that only with the Sasquatch Pkg for the electronic lockers?
KatieB75
Katie
Escape
Ok, this has probably been answered but... The Badlands says carpeted front and rear floor mats (4 door only). Does that mean it won’t be a rubberized floor On the 4-door?
Judge Rufus
Wheeler
Colorado foothills
Infiniti QX80, GMC Sierra, Mercedes SLK32 AMG,
Interesting tidbit for those ordering delivery to states requiring front license plates.
Ahem --- Iowa requires a front plate, all you Granger orderers.
From the Order Guide --p.36
FRONT LICENSE PLATE BRACKET...................................................153
Standard in states requiring two license plates and optional to all others.
So it looks like if you will be taking delivery in a state that a front license plate is required, the bracket will be installed at the factory. You might want to talk to your dealer about this if it affects you.
Sampsonrustic
Sampson
SoCal
F150 4x4
Yeah this says electronically locking AXLES not differentials... so I assume this is just standard 4x4 capability...
Headsong
But where?
Judge Rufus
Wheeler
Colorado foothills
That means they will provide you standard carpeted floor mats that will cover your rubberized flooring. You can just remove the carpeted floor mats or upgrade to the rubberized floor liners to cover your rubberized flooring.
