Thanks for catching! Yes, 275/70/R18 is the size tire for an OBX. Itās 33.2ā so almost half an inch bigger than 32.7ā badlands but 0.4ā narrower. Iāll correct my orig post if I can.I've had the same thoughts about OBX. I think you have your tire sizes wrong. A 275/65R18 is still a 32" tire, its just .5" wider in most makes and the aspect ratio is a little shorter than the stock OBX 255/70R18. A 275/70R18 will give you a 33" tire, a half inch wider, according to my research.
I do mostly beach sand driving, and you usually need a minimum 65 or 70 aspect ratio to be high enough (rubber not hit rim) to safely air down to the 15-20 lbs most beaches require (Cape Cod & Cape Hatteras National Seashore, eg).
I may upgrade to the 275/70R18 or similar, assuming the car can handle the extra 20# per tire and for on the stock 18" rims.
