Prkelly
Pat
Washougal
anyone else pissed off that their color Choice keeps changing
dnvrBronco
Highlander, Outback, 4Runner
It's been a while since Physics class, but it made me think of "moment" and "moment of force", most often referred to as "torque". Even though I now use a hitch-mounted bike rack, I will be switching to the spare tire mounted variety.
DC9atnight
Toyota Tacoma
Got the Ford's on two vehicles and have had the Weathertechs on two others. I'll be buyng weathertechs for my Bronco. Nothing wrong with the Ford's, but for the same ballpark price, i'd rather have the weathertechs.
Thanks for the tip on weathertech. Have you ever tried the Hothead ones?
Tony2x67
Anthony
New York
Jeep Wrangler
Like others have said, the 1UP USA rack is the way to go. Mine clears a 33" tire on a wheel with -12 backspacing that I have on my Wrangler. The rack folds down so you can open the tailgate. The only hassle is that you need to take the bike off to do that. Otherwise, the gate only opens partially. Since most times I need access to the tailgate I either haven't loaded the bike yet or I just took it off to ride, it hasn't really been an issue for me.
Don't know much about the Bronco tailgate hinges yet. On the Jeep if you want to hang a 33" tire with a bike rack and bike off the tailgate, you're most likely going to upgrade your hinges like I did. It'll be interesting to see how the Bronco holds up. I was holding off until MY '22 or '23 anyway, so maybe I'll know by then...
tshaw2009
Tony
Lebanon, MO
2011 F150 Lariat, 2018 Ford Edge Titanium
That sticks out quite a bit. Wouldn't you need a flag for that in some states?
In some States I would say yes. Here in Missouri, an object has to extend past the rear of the vehicle by 5 feet before it needs a flag or light if travelling at night. Personally, the bike rack they put on this Bronco is rather obnoxious with how far it protrudes past the rear of the vehicle. Just tow a trailer with your bikes at this rate as it is almost the same. Wait a bit and the aftermarket will hopefully bring a solution that will not make you look like a goofball.
pan-y-cerveza
Manitoba
Tacoma Pro
There are a few good tire racks out there (the Saris rack with tray being my number one choice) but as you say....hanging a rack and two trail bikes off the hinges isn't my ideal scenario either.
I just solidified my order for a 2021 Rocky Mountain Instinct this afternoon. Should be here in March. So I'm just imagining it, on the back of my Cactus Grey Bronco, but without the janky Yakima rack (a 1Up obviously) and the janky soft-top.
2021 will be a good year.
LadyBronco
Dani
Northern Michigan
Roller skates 🛼
We recently caught this four-door Bronco Big Bend testing with a hitch-mounted Yakima bike rack. It’s our first look at a bike rack set up on the new Bronco, and gives us an idea of its application with the rear-mounted spare tire.
The bike rack is mounted to a Ford receiver extension, which comes in shorter versions for a less extended set up.
Cactus grey looks really great in these pics! ?Thanks for posting! Great find!
jaspercasidino
PNW
2022 Bronco
In some pictures I can maybe get a hint of green from Cactus Grey if I stare at it long enough and look for green. This is straight up wet cement color. I know a lot has to do with lighting, but man that color is boring. I'm with @Rick Astley on this one and choosing a COLOR!!!
Bacon
CT
4 Dr IS MIC Outer Banks
They sell better ones that do exactly what you describe.
Quadratec sells a heavy duty extension for 2 in hitch that keeps the rack just clear of the spare tire. We have a 4 bike allen rack on it for our 4 door wrangler and everything is solid as can be.. NO Play in it at all.. rack lowers to let tailgate open, easy set up.
Quadratec also had the 4 bolt hitch with wire harness for the wrangler that we added ourselves since we are not doing any towing. Saved a bunch on a dealer added hitch. Wonder if the Bronco will have a bolt configuration for after market hitch?
Broncoak
Aaron
Eagle River, AK
1996 FSB
I have something very similar, just a different brand, but works just like you describe. Very happy with it. It'll fit 4 bikes very snug, but you have to pad it a bit to prevent them from rubbing on each other. I wouldn't pay for one through Ford to save $$$.
mdonathan56
2022 Bronco Bad,2016 Q5 TDI, 2009 Honda Element EX
Headsong
While I’ll use a hitch mount for my multi bike rack, I’m also going to get a tire mount rack that will stay more snug against the vehicle and swing away with the rear door like this one on a wrangler.
I like that.
Rigsurly
Coral Springs, FL
Ford F150
What model rack is that?
