Gotcha, saw the outer banks logoand i do not like the interior or the silver dash on the Outer Banks.
Nope. If you listen to the video, he literally says Baja mode switches it into 4H. You still get all the GOAT modes for your trim level, even if you have part-time selectable 4x4. Having the Advanced 4x4 makes no difference. Thatās why im not going to pay extra for it. I originally wanted it for driving on wet highways. But after seeing it go 70mph in 4H, itās not necessary. Iād rather switch it on myself.
I didn't watch it again yet but I understood it as having 109 on the odometer.3/4 Tank gets you 109 miles to E.... can that even be real? Seems way low. So call it 130 miles on a full tank?
Oh, yes after watching it again....I can see it though. They're beating them up and doing the turn assist dragging one wheel over and over again through sand. I have yet to see what the capacity is for fuel.3/4 Tank gets you 109 miles to E.... can that even be real? Seems way low. So call it 130 miles on a full tank?
Yes, but this in a Bronco! I did that for 7 years in my Raptor too but it's a Raptor. This is can do all the extreme off-roading but just happens to be able to do a little Raptor desert stuff too. Pretty flipping awesome!!Yall are freaking out at 70mph offroad while I'm over here doing 100+ in my raptor
I want the 4A for on road varying conditions. That's what's great about 4A mode. Not off-road.So these videos essentially prove that the Bronco can go 70mph in 4H. And since the GOAT modes handle the 4x4 automatically, there is no point in paying extra for Advanced 4x4. Makes my decision easier to stick with the part-time selectable 4x4.
16.9 for 2 door and 20.8 gal for 4 door.Oh, yes after watching it again....I can see it though. They're beating them up and doing the turn assist dragging one wheel over and over again through sand. I have yet to see what the capacity is for fuel.
Not sure how you got that from the video and not sure why it would bypass the transfer case that specifically comes with the BL and SQ model. 4A is definitely not for rock crawling (although the better crawl ratio is a benefit), itās for higher speedand variable surfaces. A locked case definitely introduces some driving dynamics that are not desirable at high speeds and while turning, particularly under braking. No way the GOAT modes can overcome the physical connection between front and rear axles in a part time case. At the very least it would limit what the electronics could compensate for in front to rear traction. You might want to try and verify that before taking an off hand comment from a test driver as a full technical explanation. I also could misunderstand the application too, thatās completely possible.Nope. If you listen to the video, he literally says Baja mode switches it into 4H. You still get all the GOAT modes for your trim level, even if you have part-time selectable 4x4. Having the Advanced 4x4 makes no difference. Thatās why im not going to pay extra for it. I originally wanted it for driving on wet highways. But after seeing it go 70mph in 4H, itās not necessary. Iād rather switch it on myself.
is that engine running hot?
Thatās the graph at the bottom. The gauge is the hash marks above it.More red to the left I think it would be!
That front camera at 70 looks like warp speed
And with the shorter wheelbase Bronco, 100 mph offroad may not end well.Yes, but this in a Bronco! I did that for 7 years in my Raptor too but it's a Raptor. This is can do all the extreme off-roading but just happens to be able to do a little Raptor desert stuff too. Pretty flipping awesome!!
4A = Ice SaverI want the 4A for on road varying conditions. That's what's great about 4A mode. Not off-road.
Thanks mom, but I think youāre looking for the Prius forum.V confused, has everyone at this event been vaccinated or are we just pretending COVID isnāt real? Where are the masks!
