7-speed shift pattern
evoaire
Evoaire
VA
maybe a bronco
So if the 7-speed is indeed a real thing, with a very low first gear, how would the shift pattern go. I picture it like this, daily driving would be just like a 6-speed but you could rock between “low” and “reverse” easily because they’d be across from each other. It would also be a bit hard to shift over to that side like how reverse is in most cars where you really have to force it over. What do y’all think?
This all day. Working a rut, or needing to switch lines, having that R straight down from L would be EPIC.
Personally I would not switch these two, it’s not natural having the R on a forward push to go backwards, plays with mind.
wvmtneer
‘Merica
F-150
My mustang has R at top left (i actually like it there), but you have to lift a collar on the shifter to get into R.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Since the Low gear is an option on the transmission, I am thinking low in bottom left is most likely. The transmission without an optional Low gear would have a normal six speed shift pattern. With the Low gear would have a logical up and right shift movement to go from Low to 1.
So the only remaining question is Top Left, or Lower Right for Reverse. I agree Top Left would be more convenient when maneuvering back and forth on the trail or in the parking lot.
eatworksleepdie
Anthony
Detroit
15' Renegade, 20' Wrangler, 92' VW GTI
In terms of shifting pattern, having L in lower left would make more sense in transitioning from L to 1st. You could shift faster having a jog vs a down over up pattern. It would equate going from 2nd to 3rd or 4th to 5th vs. 1st to 3rd or 3rd to 5th.
I could see times where you'd want/need to go from L to 1st quickly and seemlessly.
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
Saw the 7spd pic, can't wait to actually build one online, and then order it in person
Timsvtgen1
Tim
Easton PA
2022 Audi Q3
Anybody have an idea how /if pre-collision assist would work w/ a manual?
Rogues Gambit
Eatontown, NJ
Hope it's not available, too many electronics in modern cars
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
no idea. Ford only has ford 360 on its automatic vehicles. Don’t believe it’s even on the stang At all.
Timsvtgen1
Tim
Easton PA
2022 Audi Q3
So it looks like the mustang has it and several manual transmission vehicles from other manufacturers have automatic emergency braking too. Here’s an article Admittedly, It’s not a big deal either way BUT with Forward collision usually comes a whole suite of convenience sharing that technology ie. Adaptive cruise etc. Also, if Auto Emergency Braking becomes mandatory, this is good news that the manual can -somewhat- cope and not go the way of the dodo.
Dads_bronze_bronco
It has a “let me push the clutch in for you Karen” assist motor of course....
Timsvtgen1
Tim
Easton PA
2022 Audi Q3
Karens of the world will be slightly disappointed To learn that no, that is not how it works and will demand to speak to the manager of Ford.
CJay
Chad
WI
'08 Ranger FX4 (MANUAL) & '74 VW Thing
Can this be Alexa and Google enabled?
"Alexa, tell Ford Bronco to disengage clutch... Alexa, tell Ford Bronco to reengage clutch."
MaverickMan
Shane
Alexa 25% impulse power, make it so.
