Adjusting Icon stage 7 coilovers
Davelange
Telluride, CO
2022 4 door Bronco
I am trying to lower my ride height 1/2 to 1” to level out my Bronco. I was successful on the passenger side but the driver side I am not able to get spanner wrench due to the reservoir hose in the way. Has anyone experienced this and found a solution?
AK SNO RIDER
Ty
Alaska
Get a screwdriver the same size as the holes in the collar and cut the tip off it.
V1Rotate
Brevard, NC
2022 Wildtrak
You can loosen the hose connection just enough to pivot the hose away from the shock enough to adjust
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
not sure how tight the adjuster is on these , but I have seen people use a round punch about the same size as the hole, pushed into the round hole in the adjuster like an arm and turn it that way ?
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
WD40 on the threads. Full droop. Use the handle end of the wrench.
F-Spot
SoCal
Tesla, FJ
Did you back out the set screw? In the pic, it looks like it is not backed out.
Edit: nvmd. looks like the first pic is the passenger side and you tightened the set screw back in after adjusting the collar. I see the set screw is backed out on the driver's side.
