Aftermarket manual sway bar disconnect???
Jgtln
Jason
Festus
Gmc
Anyone know of any companies making an aftermarket sway bar disconnect? Would not matter to me if it was even manual.
Nickp
Nick
Phoenix
You will be able to manually disconnect it with a wrench or socket super easily, but a pull pin disconnect will probably be available within a few months.
Ford Bronco Aftermarket manual sway bar disconnect??? F1D1ECA7-ACCA-4519-94B5-71E2D6E8E5B4
Pretty sure you can just remove that lower nut and bungee the link up to the swaybar.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
No one sells one now, but they will. Should be easy enough to DIY as well. I may get rid of mine after the new Fox coilovers go in. Just have to see how it drives.
gammaguybronco
Raleigh, NC
2004 Titan
RBringing this back. Any aftermarket options yet? I haven’t found any. Doesn’t really seem necessary to buy a badlands for something that can easily be manually disconnected when needed.
bdub2you
Alexandria, VA
The key difference is that the swaybar disconnect on the badlands can be used under load, and the easy with with it engages and disengages when you hit 20 mph. The under load part is a very useful feature.
BroncoAdventures
KC
Livermore
2014 ford escape titanium ,1991 toyota 4x4 22re
I’m patiently waiting for the aftermarket to come out with a Manual sway bar disconnect .
DannyBoy83
Daniel
1981 Ford Bronco
I think this is a great topic. I would be fine with manual sway bar disconnects. That's how I've been doing it on my Jeep TJ's and it's perfectly fine. Not everything has to be push-button.
Rizz512
Rudy
Austin
C6 Zo6, Acura TSX
Oscar Espinoza is developing them. Not sure if he is on here.
Ford Bronco Aftermarket manual sway bar disconnect??? 41E2AC73-45FC-4238-8B35-26D724071D9C
I saw a few off his vids on youtube, he is def having fun in that Bronco.
I'm still shocked no other vendors are offering a quick disconnect solution.
Copperhorse73
Justin
Mooresville, NC
2022 4 door Wildtrak
I have corresponded with him on Facebook a few times. I’m hoping to be in the first batch of sales which has been “any day now” for a few weeks
