Air filters...for Off Road
da_jokker
Jeep Wrangler JKUR
Over my years of owning a ton of cars, I've done everything from using oem air filters, to K&N "oiled" air filters, to the newer performance Dry/Reusable air filters.
Not really looking for a debate on performance, as I've said, I've used them all, and even had built my own CFM test to compare.
HOWEVER, it was always for street use. I've never focused on what type of Air filter is best for off road, with all the extra dirt, mud, water, and dust elements.
I really like the idea of reusable filters, but I really am concerned about the filtration effectiveness while driving in a dust cloud off road
What route/types of Air Filter do you guys use and any long term facts or Black Labs results to back up your selection?
Erock
US
2018 F150 Alpine edition
Two stage dry filter box mounted on a flat plane so heavy particles can drop out when you shut it off. Built a system like this for the military to use in the deserts. Don’t have any test data since I only did the prototype of it, but the configuration was what the smart people wanted. I was only tasked with designing the pieces, building it and making it an easy retrofit in the field.
Thed
Ben
Raleigh, NC
'22 GX460 '16 Miata '67 F-100 '21 Streetfighter V4
I only ever use OEM filters. Most modern intakes are designed so well that most aftermarket intakes and filters are a downgrade. You won't see any performance upgrade from a filter, so why sacrifice longevity?
Razorback
Dallas
Lincoln MKX
I was wondering if there would be a benefit for having a different one based on driving situation. But probably not possible if you upgrade to a cool air intake like Roush... maybe see if there are pics from the Baja 1000 Bronco...
Bodge Garage
Kris
Millwood WA
1994 Land Rover Discovery, Jeep Gladiator
OEM for sure. People swear by K&N, I drank that koolaid for a while. Hold a K&N up to the sunlight and you will see how they filter, badly. If you can see through a filter it is not much of a filter. My intake and MAFS stay clean ever since ditching K&N, that is my only real world test results.
Just carry a spare OEM if your on an off road journey.
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
OEM with more frequent inspections based on conditions.
This! The air filtration system of a purpose build off road vehicle was designed for off road conditions, so use common sense and if running dirt roads a lot (especially behind other rigs) inspect and replace as needed.
deznut
Ron
Lost Wages
Frontier
I'm and old dirt bike guy...foam filters ( UNI) with heavy grease at inlet and sticky oil in the foam...
auto/truck always had good luck with WIX ( they have a listing for 4cyl Ranger, WA10909...I'm sure Bronco will follow https://www.wixfilters.com/Products.aspx?ct=plaf )...UNI ( https://unifilter.com/online-catalog/accessories/) sells sheets of their foam in different "grits/openings"...you would have to engineer some kind of two stage filter catching the big stuff first ( coarse foam) and then a final dry/paper filter IMO...a trip down to the dealer to look at Rangers ( if they have any in stock!)....hth
Santos
Santo
Lenoir City, Tn
1977F100:1970 Mustang Fastback
My understanding is the Bronco intake filter area is a"baffled" design to divert water out of the system, so wouldnt that divert heavy particulates out also? I agree with most that have stated stay OEM.
da_jokker
Jeep Wrangler JKUR
Thanks for the feedback. I currently have an AEM dry/resuable filter in my car which I really like but if oem/cotton/paper ones are better for filtration off road. I'll stick with those.
john
Las Vegas,NV
F150,mustang gt conv, e250
I think you were in error here sir being able to see through an air filter is exactly what you should be able to do as a Master Mechanic who has been servicing off road equipment for 40 years I will tell you that it is more harmful to over service an air cleaner as they all operate with a bit of a restriction and a new filter is intended to plug up a little bit so it's provide a modicum of restriction and if after cleaning your air filter tapping it out lightly not using compressed air but tapping out lately you cannot see daylight it is ready to replace
Bodge Garage
Kris
Millwood WA
I guess my point is if you can see through an air filter how is it trapping fine dirt particulates? I maybe could clarify I am taking about actual tiny open gaps, not just light and dark.
Aman
Aman
Northern NJ
Your point is correct. K&N states that their filters work better once they get a little dirty, instead of admitting that they let through a lot of dirt when they are new. 🤦‍♂️
85_Ranger4x4
Iowa
1985 Ford Ranger
I run wix OEM replacements and I live on gravel.
Engines with turbos can pull more air and dirt thru a filter, reusable filters have "dusted" many a turbo diesel.
