- First Name
- Tony
- Joined
- Oct 25, 2021
- Threads
- 15
- Messages
- 342
- Reaction score
- 575
- Location
- Madison, AL
- Vehicle(s)
- 2012 Toyota Tacoma TRD Sport
- Your Bronco Model
- Base
SEND IT when you have Velocity Blue
Some answers to the above.1. Your shackles can become compromised in a way that they cannot be removed.
2. Makes your vehicle looks like it has ear rings.
3. You have a tow hitch but may not always have your hitch installed, correct? So, install shackles when needed.
I SPY MOLLE PANELS....For those that may have been curious, the OEM WARN winch recovery brackets have the same width as the recovery points on the Modular Bumper which means the S.I.T.H. Shackles will cross right over. I.D. of the holes are near identical too.
The R&D never stops...I SPY MOLLE PANELS....
Hopefully not much more than regular shackles.Waiting on pricing... Look great!
What, exactly are 'regular' shackles? I've looked around any the only brand that is comparable in quality would be Factor 55. Are their products in the regular category?Hopefully not much more than regular shackles.
I think these have been popular... probably what I would have bought if it wasn't for you coming up with the SITH.What, exactly are 'regular' shackles? I've looked around any the only brand that is comparable in quality would be Factor 55. Are their products in the regular category?
I'm thinking the AR | SITH wouldn't be in your 'regular' category. The 2, 18-8 Stainless Bolts alone for the SITH are $70.00 from McMaster.I think these have been popular... probably what I would have bought if it wasn't for you coming up with the SITH.
GearAmerica Mega Shackles Orange (2PK) | 68,000 lbs Capacity - Stronger than 3/4" D Rings | Tow Shackle + 7/8" Pin + Washers | Securely Connect Tow Strap or Winch Rope to 4x4 for Off-Road 4x4 Recovery https://www.amazon.com/dp/B07Q6TF8L...abc_QCX518BYC3HE8J4A3FWZ?_encoding=UTF8&psc=1
Crazy that S.S. is that expensive.I'm thinking the AR | SITH wouldn't be in your 'regular' category. The 2, 18-8 Stainless Bolts alone for the SITH are $70.00 from McMaster.
I'll try 7/8" on that shackle mount tomorrow. From what I remember from the scan data, 3/4" fit pretty well. I'm game for bumping them up to 7/8". That's definitely not going to reduce cost.Crazy that S.S. is that expensive.
Also, seems that Factor 55/Crosby is the only Made in USA shackles I could find.
Also, your link is for a 3/4" shoulder diameter, but all the 3/4 shackles I've seen use a 7/8" pin...
Agreed, $70 each!! Maybe S.S. is not the way?I'll try 7/8" on that shackle mount tomorrow. From what I remember from the scan data, 3/4" fit pretty well. I'm game for bumping them up to 7/8". That's definitely not going to reduce cost.
