ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
how did you secure the bolt with the tube in the way?
I cut the factory zip tie and just pushed it forward. Once I tightened the bracket down, I just lifted the tube up and zip tied it to the bracket. putting it on the other side of the bracket would put it right up against the wheel well cover. That cover covers most of the shock mount with the exception of the bold we needed for the support bracket.
Ford Bronco ARB Compressor Engine Bay Mount from KR Off-Road (NOW SHPIPING) 20220117_011720587_iOS
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Some more kits en route to you guys!
we are still making our way through the orders - right now we are up to orders from 12/9/2021
Ford Bronco ARB Compressor Engine Bay Mount from KR Off-Road (NOW SHPIPING) 2FD0812B-C6D1-44B3-9B33-74320E03DB7E
DubC
Houston, TX
instagram.com
2021 Bronco, 2016 F150, 2022 Highlander
Feels like Christmas! Got my shipping notification for this and the BD Fog Pocket Kit!!! Thanks!
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yeah those fog kits came in stock today, well some of them.
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
I was looking at the dual air, did the price go up from when you first introduced this? I could've sworn it was cheaper than what I am seeing now? Did I miss out on a discount?? LOL
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yes you missed out on the discount. And the discount was 50% off our brackets during the first pre-order run. That discount is long gone.
You can use coupon code BRONCO6G and save 10% though
Dom
Dom
Phoenix AZ
That sucks! Lol. Thank you
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Hey look. I finally installed my own compressor tonight! Been to busy shipping orders to install my own, so pulled it into my (small) garage at home tonight to do it. Almost drove back to the shop to do it but figured I only needed light in the engine area. I didn't realize HOW CLOSE the Baja Designs roof lights were to the garage door until after I got out. YEEESH talk about a close call.
You'll notice how I installed mine so that the compressor wires are on the driver side. That's because I've angled my outlet port about 45 degrees. It'll clear the hood straight up but even more so at a 45 degree angle.
Worked great. No leaks at all.
Ford Bronco ARB Compressor Engine Bay Mount from KR Off-Road (NOW SHPIPING) 1642477814142
Ford Bronco ARB Compressor Engine Bay Mount from KR Off-Road (NOW SHPIPING) 1642477823200
Packman
Honolulu
2011 Ford Mustang Pace Car
Question for those more familiar with air compressors than me: when I’m airing up the tire, it keeps blowing the arb gauge out of the hose. It’s as “locked” as I can make the connection. You see the little ball-bearings that are supposed to hold it in. Is there something wrong with my hose or am I doing something wrong? This time it wasn’t in the instructions, 😂.
Ford Bronco ARB Compressor Engine Bay Mount from KR Off-Road (NOW SHPIPING) 58AD1E9F-8067-48BF-B9D4-EBA0B0E94873
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Ford Bronco ARB Compressor Engine Bay Mount from KR Off-Road (NOW SHPIPING) 4CEFDE4F-FE4C-4150-BE46-9C02B08A81DC
If the air pressure keeps popping it loose. There is definitely a connection issue.
Is that from the Pump Up Kit you got from us?
ICUGAZN
Kevin
2019 Raptor
Yeah, at some point when I'm bored, I may turn my compressor with the wires facing the engine. However, I did rotate my outlet to the 45 degree point.
ICUGAZN
Kevin
2019 Raptor
Yeah, it's not seating properly. Make sure you pull back on the hose connector and push the gauge all the way in, then release.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Another pallet of compressors arrived
Ford Bronco ARB Compressor Engine Bay Mount from KR Off-Road (NOW SHPIPING) F4626502-B409-4EA0-8703-C5758952CAF3
UtahBroncoGuy
Randy
Maryland
66 Ford Bronco / 2021 FE bronco / 2023 Raptor
excellent! Hope mine makes the cut.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Ohh there is no more "cut" we've got plenty of brackets/compressors in stock. The hard part is getting them all out the door now. We have a lot of orders to fulfill
