Fantastic! Thanks for the response and great detail with links, super helpful. I think the only thing I might do different is add a USB hub and tuck it under the rail.The arms are Medium on passenger side, Small on drivers side. Doing it over, I might have ordered both Medium and then controlled the length on driver side by putting arm at angle. I ordered the small because it was better in the "notch" where dash is shorter on drivers side. But if I want it in the middle part, it is a hair short.
The phone charges are Belkin Boost Charge Magnetic Wireless Car Charger 10W. I have these in various cars and love them. They hold pretty strong. The cables that come with them stick out to the bottom WAY to much so I replaced those with a u-shaped cable from Poyiccot. Finally, the cables plugged in to the dash also stick up too high in front of window so I put L shaped connectors there and now it looks fantastic. You need one that is USB-C to USB-C and one that is USB-C to USB-A. Finally, you need to replace the vent connector on the phone charger with a 17mm to 20mm ball connector.
