At what speed do you shift your manual Bronco into sixth?
At what speed do you shift into sixth?
  • About 45
    Votes: 1 1.0%
  • About 50
    Votes: 6 5.9%
  • About 55
    Votes: 9 8.8%
  • About 60
    Votes: 20 19.6%
  • About 65
    Votes: 22 21.6%
  • About 70
    Votes: 12 11.8%
  • About 75
    Votes: 7 6.9%
  • About 80
    Votes: 3 2.9%
  • I donā€™t use sixth gear.
    Votes: 18 17.6%
  • I donā€™t have a manual Bronco.
    Votes: 4 3.9%
  • Total voters
    102
amazingjason
CA
1987 Samurai, 1966 442
At what speed do you typically shift your manual transmission Bronco into sixth gear?
amazingjason
CA
I have found myself cruising in fifth on the freeway when I thought I was in sixth a few times.
Lowcountry Bronco
William
South Carolina Lowcountry
Majority of my driving is in town/rural highway (speeds from 20-55 but realistically 70) so if I even remember I'll maybe hit fifth, rarely 6th. Typically I'm between 3rd and 4th just because of the power band for my scenario!
amazingjason
CA
I tend to keep the revs above 1700 when cruising.
dmj
New Mexico
1961 Mercedes 180c, 1962 BMW R27
If I use 6th it's around 75+ on the flats or going downhill, but I usually stay in 5th at highway speeds. I have a Badlands with 33's, 4.7 axles and live at 5000' if that makes a difference.
wigglysqiggly
William
2023 Ford Bronco
I just shift as I go but usually around 40-45 mph. Just used to it.
Tricky Mike
21 Bronco
Bingo, we have a winner! šŸ˜‰
When I go 37's, I'm going to go to 5:38 gearing too. Maybe then I'll be able to use 6th gear...
I ran the calcs earlier today, 5.38 and 37s in 6th is still a lower RPM at a given speed than 4.70 and 37s in 5th. But it's pretty damn close to 4.70 and 33s in 6th.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Speaking of....
And in case the embedded Google Sheets sucks: Direct Link
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
I generally donā€™t use 6h gear under about 70 mph, and then only if itā€™s flat. If there is any grade Iā€™ll be pulling full boost trying to climb any hill in 6th. I donā€™t have enough highway driving time on my Bronco to know how much of a fuel economy hit there is, but the truck seems happier in 5th. Iā€™m on 33.9ā€ tall tires, I canā€™t imagine that 6th is at all useful in a Mansquatch with the 34.5ā€ tires.
Ehucek
Evan
Ohio
95 Integra, 00 CRV MT, and 20+ Others
Never. Even at 80 MPH it uses less fuel in 5th than 6th.
is this based on the instantaneous gauge or have you calculated it somehow? Genuinely curious, I drive a lot of highway and hadnā€™t noticed this but Iā€™ll watch more closely this week
