- Dick
- Apr 12, 2021
- 88
- 7,503
- 25,546
- PNW
- Website
- www.TD-Distributing.com
- 21 Bronco, 88 Bronco II, 03 Ford F250
- Badlands
- #16
Thank you!ABS module info
As best as I can tell the wires broke internally because I don't see any external breaks. The hard lines are a little tweaked, and I had to crimp the rubber with vise grips to get it off the trail, so I don't feel good keeping them.Need FDRS to do the bleed procedure. Were the sensors the only parts destroyed or did it mangle the hard lines? I'd replace the sensors and clear codes first, then if still messed up run the bleed procedure.
I need to take the wheel off again and go over it more thoroughly. In the middle of a running creek propped up with a scissor jack was not the best place for a good inspection.
