Ate a boulder, brakes locked up
Status
Not open for further replies.
Theowlhoothoot
DFW Texas
Model 3 Performance
Time to panic. The 2 local dealers are 3-4 weeks out for service. IDK if independent shops will be able to work on these yet. I'm going to stop by a friend's shop and see what he thinks. The ABS module is what concerns me now, I can change out the parts but bleeding the system is a whole nother thing.
I've yet to get a shop to touch my car for even an alignment. They have zero information on these cars in their systems for parts or service.
TX-Hans
'21 Escalade, '13 Jeep Wrangler, '21 Bronco FE
Serious question. I’m guessing insurance doesn’t consider this road hazard since it was off road?
Never thought to ask, I assumed I'm on my own on this one.
I would definitely ask! Not sure where that bolder on the dirt road came from.
Definitely worth calling your agent or insurance company. Sooner the better so they can look at it before repairs are done. Probably falls under the comprehensive property damage coverage section. "...sir, there was some debris in my way that my tire hit and it went up under my Bronco and damaged a bunch of stuff."
vrtical
Doug
GSMNP, TN
Fords
wow what a mess. Agree with flip, get all the wire/sensors replaced go from there. Almost all those sensors are fragile. Also might be ok on not needing a re-bleed of the ABS but at this point I would if its going to a shop get it all done.
Nobody
Matt
Stanwood, WA
www.snowtrek.org
1970 Bronco
Can't say I've seen anyone do that before. Impressive.
Do you know how this actually happened? Looks like it carried over from front to back. Were you in reverse? Front locker engaged? I assume traveling slowly for a creek crossing. Were you hung up at the time?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Going forward through the creek bed, sucked up from behind and rolled it up/forward. A complete freak occurrence.
Nobody
Matt
Stanwood, WA
www.snowtrek.org
1970 Bronco
Did you drop down on it wedging it between the firewall and tire and that gave enough traction to pull it up? Or do you think turning the wheel pushed it just so? Definitely a freak occurrence.
Tricky Dick
Dick
PNW
I think it grabbed when I turned the wheel left and pinched it between the wheel and frame.
Tricky Dick
Dick
PNW
Update.
Service says a new ABS sensor, brake line, caliper, and control arm are needed.
I'm calling BS on the caliper. It didn't have a single mark on it. They want $700 for that, insane, but I might suck it up and pay it just to get it over with. The little rash on the control arm is fine, I'm certainly not paying the $1200 they quoted for it.
All in the parts total $2321. Huge markups.
etmccaus86
Evan
Motor City
'22 BaseSquatch
Update.
The big question: how many of those parts have no ETA/ are "on backorder?"
Rick Astley
Up Doug's ass
d
Update.
Just be glad you're doing the labor yourself. You'd be at about $3,000 in labor on top of the parts.
Shop time at most Seattle dealerships is now at $195 per hour! o_Oo_Oo_O
Snark aside: if the brake line was sheared out of the caliper or pulled out due to the force of the rock it's certainly possible the threads need to be chased at minimum. Wouldn't like to be responsible for cleaning that port out after chasing it, you know, because brakes....
Tricky Dick
Dick
PNW
The message from service says all parts are 1 week out. That is more than acceptable if true.
I'm not on the the brake system. But if I ever decide to replace the UCA it will be with aftermarket ones done myself.
Rick Astley
Up Doug's ass
d
There is some value in having them do the brake work. Since if it fails then it's on them to correct.
1 week isn't bad for parts!
Tricky Dick
Dick
PNW
I'm a little mad about the caliper, there is nothing wrong with it. Not a scratch. But I don't have time to dick around.
Rick Astley
Up Doug's ass
d
Don't have any knowledge of such a rule/requirement/insurance carrier requriement, but it could be that they are required to suggest a new caliper any time there's visible damage to it just from a liability aspect?
Obviously not the case now but you can request to retain the old caliper and see if there's any issues on the line threads? At least then you would have a back-up caliper for the future just in case rather than being entirely out.
Anyway, the intent here is to be positive and try to give positive ideas/feedback instead of dwell on the lost $$$.
This is a crazy situation and that's a whopper of a rock to get into the wheel well! Bet if you had stock Sascratch tires on there the rock would have simply punctured/shredded the sidewall of the tire before taking out the brake line! :LOL:
Tricky Dick
Dick
PNW
The diagnosis is that it's sticking. Well yeah, that's why I brought it in, but I'm certain it's an ABS problem since it released as soon as I bled it.
While this whole thing sucks, I'm still going to go right back out there and do it again.
Status
