Badlands non squatch shock length same as Sasquatch shock length, but different.
CyberOrangeBronco
Houston
2015 Mustang GT, 2021 Bronco Badlands
I know there has been some speculation as to why the Sasquatch Package is listed as having a .4 inch difference in height vs a Non Squatched Badlands (when adjusted for tire height) so figured I'd share this here. First pic is from @BigMeatsBronco post showing his first edition (Sasquatch) front shock length, second picture is the measurement I took off of my non sasquatch Badlands.
Edit: guess below is disproven since my bumpstop lengths are identical to those shown by, and added the picture with the difference in shocks circled (look at how the resivoirs are mounted) @BigMeatsBronco
Best guess I can come up with for height difference is that the rear end of the Sasquatch packaged Broncos is riding on the longer bumpstops it comes with. Perhaps that is why some are complaining about having a stiff rear end.
Ford Bronco Badlands non squatch shock length same as Sasquatch shock length, but different. Screenshot_20220421-134703_Samsung Internet
Ford Bronco Badlands non squatch shock length same as Sasquatch shock length, but different. 20220421_134855
Ford Bronco Badlands non squatch shock length same as Sasquatch shock length, but different. Screenshot_20220424-081341_Samsung Internet
VelocityBronco
E
Bronco Badlands, F-150 FX4, Explorer Platinum
So maybe I just need to add the spring from a Sasquatch model to my Badlands to lift the front? I think there is 11 different part numbers for springs.
Does anyone know the spring part number for the front coilovers on a 4 door 2.7L Sasquatch Badlands?
CyberOrangeBronco
Houston
In your situation, you might want to consider buying the RPG perch spacer and just using the shorter spacer on the front and leaving the rear as is. Could save you a good amount of effort in experimenting while providing a known outcome.
Personally I think some of the arguments against the perch spacer have been overblown, but I'll add my .02 on that once I finish installing mine.
BigMeatsBronco
Allan
2021 FE 2 door
Thanks for doing this! So shaving the bump stops or ordering the same bump stop then could make the Badlands and SAS identical in wheel travel?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Good stuff. I've thought about finding some sasquatch fronts but beginning to think that's overkill. A different spring or 1/4" shim under or over the spring should make a BL front ride the same height as sasquatch with no change in down travel.
VVSidewinderVv
Tim
Pittsburgh, PA
20 GMC Sierra
This could probably be confirmed if someone was will to put their stock coilover back on without the boot covering the bump stop. Kinda sucks if that's the case. You think Ford would have caught that.
BigMeatsBronco
Allan
2021 FE 2 door
This leads me to believe that the bump stops are the ONLY thing different in the ramp index test that Ford provided? So any SAS with smaller bumps should be able to ramp a 700+ like a Badlands w/o SAS. Kinda funny to me.
BigMeatsBronco
Allan
2021 FE 2 door
Uh that would be me, well sorta...I Chopped the bump stomps down by ALOT and it rides like a Cadillac now!
VVSidewinderVv
Tim
Pittsburgh, PA
20 GMC Sierra
I guess you could measure the resting position against your original bumpstop length. 🤷‍♂️
BigMeatsBronco
Allan
2021 FE 2 door
Any chance you want to take apart the shock and measure the bumpstop itself?
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
If the sas had 33’s and the disco sway bar yes, the extra tire height plays into the equation and the sway bar disconnect. That’s the entire reason for the bigger bump stops. To limit travel so the tire doesn’t rub in extreme situations.
BigMeatsBronco
Allan
2021 FE 2 door
My theory, as stated in other threads, is that the manufacturer bilstein or ford decided it was a good idea to have the bumps start about 3/8 " away from touching at ride height....very dumb, but many manufacturers do this to save suspension components and frames from idiots like the guy who jumped his raptor on you-tube and bent the frame.
So when you hit a bump bigger than 1/2 inch your ass and back feels it...because it's hitting the bump stop immediately during what should be controlled up-travel.
These shocks need LESS bump stop (not more) because of the fancy valving inside and extra spring inside, the valving is special in that it changes as the shock is compressed making it stiffer towards the ends of the stroke. Alot of folks seem to forget this part.
BigMeatsBronco
Allan
2021 FE 2 door
If the sas had 33’s yes, the extra tire height plays into the equation. That’s the entire reason for the bigger bump stops. To limit travel so the tire doesn’t rub in extreme situations.
That's what the Sawzall is for 😁
BAUS67
redneck
Central PA
This is what I said from the start, longer bumps to keep the 35s off the fenders. It would only make sense to use the same shock and just change the bump between the 2 models. But what did I know back then, it was quickly dismissed. That is why when you made your thread I could not keep my eyes off of it. :ROFLMAO::ROFLMAO:
