- Matthew
- Jul 29, 2020
- 43
- 2,695
- 8,390
- Northville, MI
- 2021 Badlands Bronco
- Badlands
Interesting find and mod! I was amazed at the bottoming resistance and how well my Badlands handles when it does hit the bump stops. For my use, I wouldn’t remove them, but it reveals a lot of good information for sure.After installing the coilovers with the new tiny bumps, I took it around the block to the loading ramp I use to check flex and articulation....
The result is an additional 2”+ of COMPRESSION travel!!!
I'm running 37s for now and my goal is to stuff 38s in there this summer. So I need about an additional 1.5” of clearance between the top of the tire and fender lip (where the flairs attach). With the shaved bump stops this would make my 37s kiss the fenders during full compression. I don't want that so...
I used fabtech leveling 1.5 ” kit on the top of the shock mount with the RC spacer at the bottom of the shock mount. This gives me about 2.5” additional ride height in the front. It also allows the suspension to droop additional the same 2.5”...
Since the bump stops are shorter now, my compressed ”gap between tire and fender flair” amount is the SAME as before these mods. I still have 1” gap between tire and fender under FULL compression. But now have 2.5” more droop.
So the overall gain was very close to 2” of front wheel travel!!! And 2” + in ride height.
My front wheel travel now measures over 11” !!!
I'll be removing the rear bump stops and shaving them today or tomorrow and re-drilling the lower shock mount on the rear axle 1.5” higher. This will lift the rear to match the front AND will also allow the rear to compress to the same position it is now. (About 2” gap under full compression w/37s)
I do realize the new short bump stops might not have enough bumper to protect the shocks from damage if the truck was jumped or bajaed through the whoops, but for the next few months I'm just doing slow speed rock crawling.
I'm just trying a few things out with the stock SAS suspension while waiting for the Fun Runner long travel setup to be released. So some of this is temporary.
