- redneck
- Jan 3, 2020
- 24
- 5,048
- 15,449
- Central PA
- 88 5.0 LX, 08 F-150 Stepside, 22 Expl Timberline
- Base
This is what I was thinking too, but am thinking of using a SVC perch collar on just the front for a 1" lift. They are looking into making a front only kit available.Good stuff. I've thought about finding some sasquatch fronts but beginning to think that's overkill. A different spring or 1/4" shim under or over the spring should make a BL front ride the same height as sasquatch with no change in down travel.
The shocks are different though, if not in length, the reservoir for the Badlands is pointing up, and Sasquatch is pointing down. Why? Don't know. Is the perch location different between the 2 shocks?This is what I said from the start, longer bumps to keep the 35s off the fenders. It would only make sense to use the same shock and just change the bump between the 2 models. But what did I know back then, it was quickly dismissed. That is why when you made your thread I could not keep my eyes off of it.![]()
Right now I have the RC 1" level to put on and I was going to use 2 of the 3 spacers in front to get about 3/4" and the leftover in the back. I don't want a lot of extra height.This is what I was thinking too, but am thinking of using a SVC perch collar on just the front for a 1" lift. They are looking into making a front only kit available.
Or go all in for the 2" kit and do all 4 shocks...
Have you seen the Bilstein 6100 shocks for the Bronco coming out? Uses stock springs and different perch heights for lift adjustment. 0-1.9" height adjustment.Right now I have the RC 1" level to put on and I was going to use 2 of the 3 spacers in front to get about 3/4" and the leftover in the back. I don't want a lot of extra height.
Would be more expensive then perch spacers, and is really doing the same thing, but with more adjustability in height selection.
Sorry to resurrect an old conversation, but how did that RC level work out? Putting a spacer in the back fit ok?Right now I have the RC 1" level to put on and I was going to use 2 of the 3 spacers in front to get about 3/4" and the leftover in the back. I don't want a lot of extra height.
Decided against it in favor of Icon shocks. Haven't put those on yet either.Sorry to resurrect an old conversation, but how did that RC level work out? Putting a spacer in the back fit ok?
