Beach driving best in 4 High or Sand Mode?
Dtom417
Derek
Portland Maine
Infiniti g25x
Just wondering if most of you just put it in 4 high or use the sand mode . I tried sand mode but the gearing was a little much so I switched to 4h and locked the rear . Just for reference I have a 2022 Sasquatch .
AZMikeL
AZ
2022 Bronco Badlands 4dr, 2016 BMW 435i
Sand mode will have more aggressive throttle mapping and shift points. It also engages the rear locker (which you can turn off)
Not a ton of difference, from normal mode. Try both with and without the rear locker on and go with what you like the most.
I do most of my off roading in sand mode (unlocked) as I like the better throttle response and the holding of the lower gears longer.
jbellousux
Austin
‘13 Land Cruiser
Sand in 4H.
This was at the southern end of the 60 mile (120 round trip) Padre Island National Seashore trek I made back in June. I was able to drive most of it in 3rd, with cruise=30mph, so as to better enjoy the scenery.
BroncocnorB
Paul
1965 Cobra,
If it’s not deep (like Daytona) you can do sand in 2WD. 4H and air down otherwise.
RhodeIslandRed
Northeast
www.bronco6g.com
TD5 Defenders
Beach sand is not a single thing. If you go out on Nauset on the outer Cape, the sand is so fine, you have to air down. Where the beach sand is more granular and hard-packed, you can get away with 2H.
You gotta play around with what works for your conditions and rig. Generally, I would try to not travel around with the rear locker engaged. Lockers are for getting unstuck, or dealing with a specific obstacle or challenge. Driving on the beach should not require lockers.
SpringTXOR
Jason
The Woodlands, tx
1986 Bronco XLT
Sand in 4H.
I did the trip back up at 45-55 mph, in mostly the rough deep sand. So much fun! My other half hit 60 at one point going down.
jbellousux
Austin
‘13 Land Cruiser
Nice!
I only had the guts to do twice the legal posted speed!
da_jokker
Jeep Wrangler JKUR
Baja mode?
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
4H. Less air the more sand. 18 PSI the lowest I have gone so far. Only need 4L if it’s really bad.
lakesinai
Charleston SC
Depends on the beach, the softness of the sand, and the speed limit, so you don't have alot of gear hunting.
fields_day
San Antonio
2022 4dr Badlands - 2023 2dr Black Diamond
I recently did all 60 miles (both ways) of the Padre Island National Seashore in 2wd. I aired down to 20 and turned off traction control, zero issues.
