Bigger than the Explorer?
Jake_zx2
Jake
2018 Mustang GT
What does the explorer lack that you want?
Ground clearance, low weight, smaller footprint, removable top and doors, lower price tag, and good looks
phillyfx4
Rich
Phila., PA
2008 F 150 4X4
The Jeep is saddled with a problem that the Bronco won't be: to keep aligned with heritage the jeep must have protruding fenders. This makes the interior volume small compared to the overall width. I have owned 3 Bronco II's with a 94" wheelbase and a '05 LJ (unlimited) Wrangler 103" wheelbase, more or less same overall width, the BII's had much more useable interior space compared to the LJ.
I had an 1988 Bronco II Sport with the 2.9L V6.....thanks for the wheelbase info(94"). I honestly can't recall but did they have an IFS or SFA ?
I REALLY liked it till the 2.9L blew its head gaskets, TWICE :headbang: …..ended up putting a Jasper reman in it, went to NH on a fishing trip, nasty storm blows thru the campground and a tree fell on the Bronco bending everything, FRAME, total loss . That was 2001 . I hope the new Bronco's have that type of room inside …… What do you think will be the wheelbase for the 4 door model ? thanks :beer:
dmtndan
1991 Silverado, 2014 Malibu
earlier on this thread I think we all pretty much agreed wheel base For the 4 door would be around 118” as that matches up with the wrangler 4D, Defender 110, and the current Explorer.
Carolina Jim
Highlands
2021 Bronco 2-door
I read 112"....but I can't find the source
dmtndan
I recall this in my first statement on this thread, but couldn’t remember where I read it either...
6 inches could be enough for most people to concern over in this context, it could effect break over a lot, interior spacing, etc. depending on design
Carolina Jim
Highlands
2021 Bronco 2-door
OX1
jackson nj
59 Brd, 70, 78, 79 Brncs, 84 LTD 331, 86 Cpri 5.0 Trbo, 17 Fsion Sprt, 21 GT 500
It's not just heritage, It's the ability to go where no other rig made today will.
The body shape already kills any other vehicle that is going to come out by
giving you a fighting chance of not trashing the sheet metal on a new $50K rig.
Hope the new Bronco has large flexible flares in the wheelwells (don't have to stick out,
but need to be removable for larger tires or just sheet metal protection/elimination).
Hope is has bumpers that run well up into the 1/4's and fenders, preferably virtually eliminating
any permanent sheet metal, at least 12-18 inches from lowest point of body line, in front of front
and behind rear tires.
Ford Bronco Bigger than the Explorer? main.php?g2_view=cor
jimbo92
Greenwood SC
1992 Ford Explorer
Somewhere along the size of my 1st gen Explorer would be good. Tons of usable room. The 103" wheelbase is perfect on 35s.
Ford Bronco Bigger than the Explorer? 1578955200447
BAUS67
redneck
Central PA
STOP THE PRESSES !!!!!!!!!!!!
its an explorer and it has SFA !!!!! that cant be an off roader it has to have IFS :)
seriously ………….. nice job on the rig !! not to mention this pic says it ALL LOOK AT THE FLEX !!!!!!!! NEVER HAPPEN IN IFS !!!!!!
BAUS67
redneck
Central PA
F1 cars do just fine with motors smaller than a bottle of coke.
in case ya'all didn't know this ..... in the late 80's early 90's F1 started with fly by wire, drive by wire, electronic throttle activation, whatever term you would like to use. What are all vehicles now ????? It all trickles down.
how does an F1 car run from 1000 RPM to 20,000 RPM flawlessly ?? with electronic lifters. yes that's right just like and electronic injector squirts fuel in milliseconds instead of through a jet size by vacuum the lifters are not pushed by a cam anymore. I believe I heard the announcers say the valve opens and closes at 300 times a second at 20,000 RPM. Its mind boggling how this stuff works. and guess what it will end up in our production vehicles before you know it.
what's gonna happen when the pullrod suspension comes into play everyone will be screaming to the high heavens that shock ain't up and down it's sideways. It can't work like that. LOL
sorry didn't want to be off topic but just wanted to make the point about how technology can get carried away and it is supposed to be for the better. It's just more expensive.
I can't wait till the first person comes in and needs a replacement tailgate for their '20 denali and I tell them it's 5 grand !!!
frinesi2
MD
'92 Pajero 2.5TD, '99 Land Cruiser '15 Golf TDI
Electronic lifters? What? They have nothing of the sort ... they have fixed cams (they don't even use VVT) and use compressed air instead of conventional springs to get to 20,000 RPM (although in the v6 turbo era they're actually limited to 15,000 RPM and tend to shift closer to 13,500 ... oh and guess what happens when there's a leak in the pneumatic spring circuit ... good bye engine). Sure they're technological marvels but let's not start making things up ...
Also they use pull-rod suspension purely for the aerodynamic advantages, and in fact I'm not even sure any teams are using pull-rods any more (only a handful of teams even used them in the first place) ...
Very little F1 technology has any real application to road vehicles and it's been that way for quite a long time.
One thing and one thing only has been the primary reason for road car engine innovation for at least the last 2.5 decades - government mandated emissions control.
BAUS67
redneck
Central PA
Thank you for the correction. Just heard the announcers talking about it and thought they said it was electronic. I am not trying to BS hear just trying help inform in case someone doesn't understand.
I will stop typing and just read. LOL
Grove_LA
Colin
Southern California
2010 F150
Kind of, keeping it in the Ford family, the Explorer is a tire change away from being able to tackle everything you need. It also has a panoramic and fixed roof to mount different cargo racks and an open air experience.
The BabyBronco will also conquer those needs but it seems ego gets in the way of admitting a vehicle with Baby in the name fits the bill.
I agree that it will probably meet the needs just hoping the Baby Bronco won't be tooo small.
Stampede.Offroad
SD
junk
It will be very close in size. The main difference will be height.
Just look at Escape dimensions, it ain't small.
lrtexasman
Larry
Dallas, Tx
2022 BL traded for 23 Tundra waiting on BD Order
I would add that some of us want to be able to tow off-road camper, small boats and dirt toys as well as overlanders/explorers/hunters who carry rooftop tents and gear to lesser known locations that requires true off-trail ability (thank you off-roaders). Perhaps we should split into three groups (off-roaders/climbers, off-trail/overlanders/explorers, and urban cruisers/style enthusiast ).
