The_Axeman
Sean
Montréal, Québec, Canada
2021 Ford Bronco 4dr Badlands 7MT
Here’s a quick install video I did for a rear chase/reverse light setup. Hope it helps or gives some ideas.
And a few pics taken during the install:
Ford Bronco Bronco rear chase / reverse light install 87CF4BA4-B04C-40C5-B3D9-C481FBEBAA16
Ford Bronco Bronco rear chase / reverse light install 5D3FA654-7367-4050-91A8-7569D9A42409
Ford Bronco Bronco rear chase / reverse light install F0A24AD5-95A6-43B7-BD18-568F9EFB778C
Ford Bronco Bronco rear chase / reverse light install 1F0C1424-D42A-4E04-965A-6523ABE164B9
Ford Bronco Bronco rear chase / reverse light install 702C807E-4C2C-45B2-991F-2D2ABD069845
Ford Bronco Bronco rear chase / reverse light install 5B9D6421-9261-4C49-B6E7-9124176E5665
Ford Bronco Bronco rear chase / reverse light install CD903889-0834-43C7-99E9-F439A69D3598
Ford Bronco Bronco rear chase / reverse light install 1B0715ED-85F8-4B45-A4DD-E550AACAB56E
Ford Bronco Bronco rear chase / reverse light install 51B1A91A-4990-44CC-A337-4DF1D74F5BBB
Ford Bronco Bronco rear chase / reverse light install 43424DDE-D5D1-4A88-8AA1-B6367D13CE22
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Looks good! I've been doing research on a reverse light for my upcoming Bronco and you posted this thread perfectly. Thanks!
The_Axeman
The_Axeman
Sean
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Looks great! Could you take a close up picture of the light (off) please? I've also been looking at options for a reverse light.
Thanks!
604Bronco
British Columbia
www.bronco6g.com
The Rough Country Bumper has spots to add these lights as well. They are a big help in many situations.
Although I have no reason for strobing rear lights, this just looks awesome, haha.
If you don't mind me asking, why did you add them? Do you need them for work, or are you just flexing to your friends? :ROFLMAO:
Gtrekker
Gary
Hey, just thought I'd chime in on your reverse light.... an easy fix is your 7 pin trailer plug has reverse in it. Splice into it and ground the light. Done!
FloatingMoat
Rick
San Diego, CA
Badlands, BMW F800GSA & Onewheel Pint
Typically these are used when off-roading to help the person behind you in your crew follow you in low light situations.
Lanman
South Carolina
Audi RS e-tron GT
My wife has two pod lights installed in her back bumper. They may be a little low for chase lights but they work great as reverse lights. I don't have a good picture of them but you can see them in this one.
Ford Bronco Bronco rear chase / reverse light install Bronco 3
604Bronco
British Columbia
www.bronco6g.com
Not bad - I was thinking of putting a light here too, but would opt for a small LED bar instead of two pods. However, now that I have a swing-out hitch extender that blocks this, I'm glad I didn't go that route now :ROFLMAO:
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
They serve multiple purposes.
1) Strobes help when people are behind you on a dusty trail and visibility is low, so they don't run into you.
2) If someone is tailgating you, strobe em.
3) They're fun at parties.
4) The solid light helps when trailing in the dark and you need to reverse out of an obstacle.
5) They're great at parties.
I have the Baja kit, but @The_Axeman's kit is quite nice as well.
My only qualm would be that you'd have to use 2 aux switches, but that's about it.
Ford Bronco Bronco rear chase / reverse light install PhotoGrid_Plus_1663597669230
The_Axeman
The_Axeman
Sean
Thanks!
Will do - but I’m working a 24hr. Here’s a pic from Amazon as well as the link. Mine are the flush mount version.
Flush Mount Led Pods, MOVOTOR Combo Offroad Driving Lights with Separate Amber Solid/Strobe Side Shooters Backup Reverse Lights Cube Working Lights for Truck Jeep ATV SUV 4x4 https://a.co/d/i0QpAyx
Ford Bronco Bronco rear chase / reverse light install 927DF623-D299-4311-BE3E-63018791EC43
The_Axeman
The_Axeman
Sean
Good thinking! I chose not to have it on my reverse light though. It’s quite blinding. I’ll only use it when nobody else is close by.
The_Axeman
The_Axeman
Sean
Others have answered - but I primarily use them - as mentioned- when on a dusty road in a convoy. However - they’re great in a snow storm or heavy rain on the highway to keep visible.
az_dirt
Jay
Bronco, Squarebody, Prerunner
I added them per NORRA chase light requirement - safety. Used aux 6. Blinding at night for sure but they work cutting thru the dust during the day. Would work great with foam guns, whistles, and tequilla shots too but that was 20 yrs ago for me...
Ford Bronco Bronco rear chase / reverse light install IMG_1018
