Can i run the wires for the ditch light to another location if i dont have the Upper Aux Switch Panel?
Tarponflyguy
Rob
FLORIDA
'23 Bronco Big Bend 2 DR
Or am I SOL?
Tarponflyguy
Tarponflyguy
Rob
FLORIDA
I know how to change a light bulb and hats about it. Someone will have to explain this to me like i am 5.….lolol
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
Have someone else do it then. Its simple IF you know what youre doing. You can also create huge problems for yourself via electricity.
Baja Bronco
2Sun AZ
22 Ford Bronco, 20 Ford Raptor
It’s basically point to point. I can only comment on Baja Designs lights, but their harnesses come with everything. Relays, fuses, switch. Switch located somewhere in the cabin, hot and ground to battery.
Tarponflyguy
Tarponflyguy
Rob
FLORIDA
This i semi-understand. Seems like location to put the switch will be the kicker.
Baja Bronco
2Sun AZ
Kicker panel might be a little low / hard to reach? If it were me, and I had to pick a spot, I might choose that big plastic panel piece under the steering wheel. You won’t have to stretch if it’s directly under the wheel, or to either side. But it’s your truck, pick what you like. Glad I have Upfitters. Less hassle.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Hire someone, buy a buddy some beer or book it into the shop. You might just end up starting an electrical fire if you aren’t that adept with wiring.
Take a look at plug n play harnesses if your lighting manufacturer provides them. They are semi fool proof and relatively easy to route and install.
IIRC, all broncos had the upfitter wiring pre-ran as part of the vehicle harness… you could get your dealer to install the Aux panel and switches too
Tarponflyguy
Tarponflyguy
Rob
FLORIDA
Ok the Baja Designs with their toggle switch is perfect and running the switch to a spot just below the headlights switch s perfect and looks very easy!
Thanks for everyone’s help and suggestions!!!
Fonz54
Lou
Monterey, CA
Jeep Commander, Porsche Cayenne, Mercedes C250
Pugsly
Clayton, DE
2014 Ford Fusion
