Aux Switches with Pre-run Wires
Raptor911
Raptor911
Ashburn, VA
2019 Raptor, 2018 BMW M2
This is what I am talking about >> https://www.wirebarn.com/30-Amp-Automotive-Relay-with-6-Socket-Pigtail-Plastic-Tab_p_193.html
or this
https://www.amazon.com/ONLINE-LED-STORE-Switch-Harness/dp/B01NBAO1SA
A relay actually does not have a fuse...Usually a fuse is either wired into a relay box to use for the acc, an inline fuse is used, or the accessory has it's own fuse...all the relay is an electronic A/B switch (in a single pole, double throw relay)...or a DPDT (double pole, double throw) is like two A/B switches in one (in very layman's terms)...
Pole - how many inputs
Throw - how many outputs
Again in layman's terms because a SPDT can be used in reverse (like two inputs and one output)
tmobileguy
Aaron
Tallahassee, FL
'14 F-150, '05 F-350, '13 JKU, '11 Jag XJL, '11 BMW 740LI, '05 Bentley GT
So the first link actually does not have a fuse with it...the 30a is referring to the capacity of the relay, but absolutely no fuse with it....
The second one, it looks like they attached a fuse holder to the side of the relay and are selling it as a combo unit...but a relay and a fuse are definitely two different things with two different purposes...
Advertisement
Advertisement
