Modular fog lights without AUX switches
Ontario51
Lucas
Ontario canada
4 door outer banks Sasquatch
I’m looking at buying a set of 3 pod fog lights to go into my bumper, and i want to get a set with the amber DRL option. But i do not have the factory AUX switches, so what are my simplest options for grabbing power for the DRL? Will be adding a switch for the regular fogs but not sure what to do for the DRL
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I would tap into the DRL wire. If the amber DRLs are low current, you'd probably be fine with just that, but could throw a relay on it if concerned.
Bud2020
FL
Badsquatch 2.7 Lux
This is how I would do it for that application even with AUX switches. Doesn’t make sense to me do have to toggle a drl on and off manually. Would 100 use a relay though.
los7883
TX
Chevy Corvette
Anyone know which headlight wire goes to the DRL?
Ducati1098
