Agrod
SJ, PR
22 4dr OBX
ArtHughes
ArtHughes
Art
Beaverton, Oregon
www.arthughesphoto.com
2023 4Dr Bronco Badlands w/ Sasquatch
If you dont need to look at the screen, ever, and its just to connect to your Ford System - ok great.
Actually I like to play a game by staring at the phone for as long as possible until I get to test the Sasquatch ground clearance 😅
ArtHughes
ArtHughes
Art
Beaverton, Oregon
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Between this and your sound system install, you definitely are way more handy than I am!
Well done - This looks great! I also found it difficult to find the perfect phone mount, but I ended up going with one that takes up one of my valuable cup holders. Not the end of the world, but I like you're setup!
You don't like the rail concept?
ArtHughes
ArtHughes
Art
Beaverton, Oregon
Because of the angle of the arms coming off of the dash with a rail, you get significantly more vibration and device shaking than with an arm supporting the device from below. That is my only objection to a dash rail system. If i needed to mount a ton of items, that would certainly be the way to go and you just deal w the device shaking. 👍
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I don't hate it, I just don't really want my phone that high up on the dashboard. My phone holder in my cup holder has a long arm which extends it to just below the centre screen.
I think part of my issue with the rail is I haven't actually tried it or found an option I love. Something secure, but easy to remove when I get in and out of the vehicle. I'm not opposed to it, but hasn't been the top of my accessory list.
ArtHughes
ArtHughes
Art
Beaverton, Oregon
I feel the same way, especially with regard to the quick insert and removal when in and out of the truck a lot. Any arms leveraged off the dash concern me with that load transfer as you pull at the device over and over again.
What I made is so rigid that it doesnt move when i pop the phone in and out, so i dont feel the need to support the arm or cradle to manipulate the phone. Its been the first phone solution ive been totally happy with.
Glad you've found a solution as well 😀
Underground Graphics
Greg
Houston
www.undergroundgraphics.com
22 Bronco, 20 Jeep Gladiator
We did something similar using a motorcycle RAM handlebar mount w/ M8 screw. (I hope that's right, I dug through my spare parts bin) and a short, a long and a ball connecter, topped with a Quadlock charging MagBase. We had to use a zip tie to keep snug against the Bronco OEM handle.
Seems like alot of work, but it was perfect for my needs. Kept the phone away from the passengers and in perfect reach for me, ...and charging!
Ford Bronco Custom Console Offroad Phone Mount Ram Mount Bronco
ArtHughes
ArtHughes
Art
Beaverton, Oregon
Nice.. i dont use the magbase system but would adapt mine in a similar way if i did. Looks good!
ArtHughes
ArtHughes
Art
Beaverton, Oregon
TY for the cost outline. Would it be possible to have a longer arm off the mount - with a bend - to still have full usage of the console grab/handle.
For sure. Ram makes all sorts of different arm lengths that could be combined to achieve any angle. I don't use the handle so i wasn't worried about additional clearance, but it could easily be configured that way.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Well, if you ever are interested, I might have one you can try...the AR BAM for Badlands...
Let me know!
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Keep the arms short, I even have an iPad Pro hanging off mine!
