DD Hitchpod SSC1 Kit installed
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Got the HitchPod a couple days back. The rig required a few hours to thaw before I could access the 7 Pin wiring harness. Nevertheless, it fit, and works as expected! A 10MM to remove the 7/4 Connector, pull the closest factory retaining xmastree plug/ziptie thing out, and add the inline harness. Zip tie it all up as you'd like.
For $100, its a great lil mod that is all benefit with a decent amount of output (~1000Lumens). The flood pattern is nice and soft; it doesn't overwhelm the backup camera
Ill take some night shots and update soon.
Update 1: Added Night shots
Update 2: @4x4TruckLEDs.com Resistor clipping mod for the harness worked
Ford Bronco DD Hitchpod SSC1 Kit installed December 28, 2022_2369-LR
Ford Bronco DD Hitchpod SSC1 Kit installed December 28, 2022_2374-LR
Ford Bronco DD Hitchpod SSC1 Kit installed December 28, 2022_2439-LR-2
Ford Bronco DD Hitchpod SSC1 Kit installed December 28, 2022_2435-LR
Ford Bronco DD Hitchpod SSC1 Kit installed December 28, 2022_2385-LR
Ford Bronco DD Hitchpod SSC1 Kit installed B385CBBF-BCDB-4F8F-B443-6C6C932E1764
Ford Bronco DD Hitchpod SSC1 Kit installed 45180CB9-D158-4588-8A78-82E3430786AA
Ford Bronco DD Hitchpod SSC1 Kit installed 123767F5-54BE-414E-BB96-01234B5CC071
Ford Bronco DD Hitchpod SSC1 Kit installed F83E199C-ED04-4752-9EB0-862D906AE9A1
Ford Bronco DD Hitchpod SSC1 Kit installed 1D564A3F-DB3F-4ABF-9F64-7838603F2DB9
Ford Bronco DD Hitchpod SSC1 Kit installed A68527FB-16A8-4898-84FF-BE97F92C796D
Ford Bronco DD Hitchpod SSC1 Kit installed 00AD480B-D037-4189-9A53-FF8D306C79E3
Ford Bronco DD Hitchpod SSC1 Kit installed AF7B0FB2-ABE4-44D3-9C33-5A8586696209
Ford Bronco DD Hitchpod SSC1 Kit installed 04318C6E-21DC-49AB-9D56-F22AC0DBF971
Ford Bronco DD Hitchpod SSC1 Kit installed F96D3EE7-8518-4CEA-8840-8BDE712764B5
Ford Bronco DD Hitchpod SSC1 Kit installed 9F7BEE0B-634C-4966-BD55-93BCD6674160
Ford Bronco DD Hitchpod SSC1 Kit installed 81B1DF00-2921-4F0F-8C8E-60768AF4B245
Ford Bronco DD Hitchpod SSC1 Kit installed 4C33B981-1A6E-4D35-A54E-524EBE3548F6
Sids
Argyle,Texas
2021 Navigator, 2017 F350, 2015 Odessey (dog car)
Thanks!! I will be installing mine this weekend.
NatureMan
United States
Does the bronco acknowledge a connected trailer?
Badsquatchman
Brent
Maryland
motorcycle & 93 Z28
Thanks, I’ve been looking at this. Can you see better backing in low light? your post states it doesn’t wash out camera view but, I’m most interested in getting a better night picture.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
It does not, at least the ones we sell do not. There was a running "fix" that we worked on with Diode Dynamics to resolve the issue.
@Diode Dynamics @4x4TruckLEDs.com
Im spec’d with the High Pack and It does indeed throw/trigger trailer connected notifications. I have disabled BLIS, Crosstraffic, and Parking aids to try to reduce the amount of chimes/buttons required to start the truck.
Perhaps @Ford Motor Company can add a “Trailer Override” or “Not a Trailer” buttons to allow people to use the built in features while also using 7/4 Pin connectors to power mods
4x4TruckLEDs.com
Adam
Lindenhurst, NY
if you received a C1 hitchpod and it didn't ship from us THIS WEEK then you need to make a fix on your hitchpod. ALL hitchpods sold by us as of THIS WEEK and ALL C1R hitchpods sold from us (ever) work properly.
BUT C1 hitchpods that you got LAST week or earlier need to make the following fix:
1) Remove the black tape on the trailer harness
2) There are 2 resistors. One resistor goes from BLACK to YELLOW and the 2nd resistor goes from BLACK to WHITE. Look for these
3) CUT the resistor wire (it's the exposed metal wire). I recommend cutting it FLUSH with the resistor/wire.
4) Re-tape your harness
That's it.
Basically Diode Dynamics installed 2 resistors on the harness which don't work on Ford vehicles, as the Ford trucks think a trailer is connected and will disable your cross-traffic alert system.
If you don't do this the Hitch Pod WILL still work, but your cross-traffic alert system will get disabled. So simply cut those 2 resistors and it'll fix the issue.
We tested this in-house AND Diode Dynamics tested this in-house also (they provided us the instructions to test on some additional Ford trucks like a Lightning).
Here is one of those resistors shown with the wire still sticking off (cut it flush)
Ford Bronco DD Hitchpod SSC1 Kit installed 1671480342885-png
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
That's it.
I pre-ordered on day 1 thru DD.
Thank you for the heads up with how to Mod this!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Not us. BOOO!!!!!
Then you got one that was most likely NOT fixed before it shipped.
Ogre
James
'23 BD 2dr 7MT CG, '18 Indian Chieftain
Where can I find the 4-pin instructions for this? All I found was small modifications needed, not what they are.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Fhats a nice looking rig!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
These are not designed for 4-pin trailers... 7-pin trailers
Boreal
Boreal
Colby
MB
2022 Badlands 2DR
Check the first post, it has been updated with some shots
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Not too shabby for a $99 plug and play option that takes 60 seconds to install
