Talked with my dealer yesterday, this is the information he received from Ford:I you look at the dual top with modular option price, since the four door already has a soft top, that should be a good proxy for how much the modular hard top will cost as a part.
Black Modular Painted HardTop will be available to order per Ford in December. It is a late availability item, so that means it does not appear on Build & Price but we can order that. It would simply move back the production date to when that is available.
> > White Modular Painted HardTop is going to be available on 2022 Broncos per Ford. Also per Ford, some current reservation holders who reserved at later dates will have their model pushed into a 2022 model year Bronco, meaning they would at a later date be able to edit their order to add that. Since you are an early reservation holder you are most likely not among that sub-group.
> > Ford has not given me any info on the Body Color Matched Modular Painted HardTop. I anticipate that is a late availability option again.
> > Ford is indicating that all of these will be available through our accessories department as they become available to the factory. This means that if you are amenable to it, you can order your Bronco with the standard roof option at no cost, then swap it out when your preferred option becomes available..
> > White Modular Painted Hardtop
> > Body Color Matched Modular Painted Hardtop
Cost $1895
