So I installed my fogs last weekend. My driveway is steep AF, so in order to line them up, I had to go find an empty wall on a flat surface. Luckily my son is practicing baseball in this industrial park, so I was able to drop him off and then go find an empty garage door.
anyway. I have 2 sets of lights. 1 yellow, 1 white. I looked it up online and it said to measure the distance up from the road to the fogs (~23inches), park 25ft away from a straight wall and then measure the same distance from the road to the wall you're shining on. Then measure 4 inches below that, and that's where the top of your fogs should line up. Easy enough.
I did all that, and here is the result. (With headlights off)
What is bothering me is the curvature upward.
Then I remember, because of the bracket design, the fogs are actually installed upside down.
Could this be a result of that?
Has anyone else experienced this?
Is there something I can do about this?
Or is this normal?
I'm afraid of blinding any oncoming traffic.
Oh, and here's a pic with the headlights on, for what it's worth. The arch isn't too much higher than the headlights. So maybe it's ok?
Or is this normal?
