Does anyone have payload and towing capacities for the different trim levels of the new bronco?
2Jeeps&PatriotX1
Denver, CO
'23 4dr Badsquatch, ā€˜05 LJ & ā€˜17 F150
There has been lots of chatter that the offroad suspension is crap for towing and the towing suspension is crap for offroad ......Which explains Jeeps low tow rating also.....Want Offroad, get a Bronco....... need to tow, get the Ranger....7500lbs as i recall.
Want both...buy a Gladiator.
HoosierDaddy
Indiana
I want to drive it, not store it at the dealers "awaiting maintenance " lot.
Lord knows you can get them cheap as fuck right now though. .... nobody wants them.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
I noticed that the ratings are the same for all trims and vehicles as of now. There is also a tow package available without any details on specific changes to capacity. My guess, no class III hitch or bumper is specified yet, so the put the single rating out for all trims and powertrains. I would expect a slightly lower rating than the Ranger, based on suspension and wheelbase, but adding a class III hitch and tow package should get you in the 5-6k lb range. I have worked in and around the insurance industry for 25 years and never saw a claim questioned for exceeding capacity. Every contract is different, so itā€™s certainly possible!? You may be in a bad situation from a liability perspective (for example, a jury would probably take exceeding capacity into consideration related to your responsibility if someone was hurt and it was tied to towing and exceeding the limit of the vehicle).
Fosters
Phoenix AZ
2019 Ford F450 2018 Mustang eb premium vert, 2013 Mustang 6A, 2004 mustang gt, 2001 Jeep Cherokee, 2019 Can-Am Maverick Sport X RC
Wheelbase has probably more to do with it than suspension up to a certain point... Raptor is still somewhat respectable, though still lower than the equivalent crew cab 3.5EB F150. But the F150 does have a big wheelbase advantage on the bronco... Again, what's good for towing (longer wheelbase) is bad for offroading and viceversa... Basically a combination of the 2.
HoosierDaddy
Indiana
Good point, either way, 2 door or 4, Ford has affirmed the tow rating will be set at 3500 lbs. for all models.
The tow package will give you a 2" receiver hitch and wiring.
PretzelDay
Max
2018 Challenger/ 1970 Mercury Montego MX 351C
stupid low tow rating.... guess I'll be getting the new F-150 "EcoPower" or whatever its called
Me too! I was hoping for 5000lb. I gues i may have to buy the Gladiator after all...
LarryZiegler
Larry
The problem with the Raptor F-150 is itā€™s cargo load capacity, which is about 1100 lbs. Add a trailer with a tongue weight of 500 lbs, a 100 lb WDH, and the truck is rated to carry only 500 lbs, which includes passengers. As for the Bronco, the same issue occurs. It has a 1170 lb cargo capacity, a 3500 lb trailer (using max tow rating), has a tongue weight of 400-450 lbs plus 100 lbs for WDH, leaving 600+ lbs for passengers and cargo. Use a 5,000 lb trailer and you now have a tongue weight of 600-750 lbs plus another 100 lbs for WDH And the Bronco can only carry 300-400 lbs inside
MJJ
Sean
Iowa
JL Wrangler Rubicon, Jeep Wagoneer, Colorado ZR2
Dumb question ...what does wdh stand for?
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
So the FJ is rated for 4700lbs, and has a 105ā€ wheelbase.
It is a combination of lawyers and suspension Iā€˜d guess. (Hate how conservative US ratings are compared to Europe and Australia for the same vehicle.)
Jhuff
J
Toyota Tacoma and DR650
So if the rumors are true and a class III hitch won't improve the ratings, and we assume the suspension is major part of the derating, aren't there airbag systems which would could stay soft for wheeling, but then be firmed up for towing when needed?
PDiddy
Paul
4Runner
Maybe we have to wait for the big bronco, based off the F150 frame, for big towing.
timhood
Tim
Several
I sure hope the 2.7 bumps towing capacity up to something like 5,000 lbs (or more)
The Ranger with the 2.3 and the trailer tow package is rated for 7,700. I was hoping for 5,000 no matter what. Would be nice to be able to tow a reasonable-sized boat.
