emulous74
Seth
Austin, TX (Pflugerville)
'19 ZR2 Bison D , '23 Bronco 2DR, MT
When I was growing up, my first car was a new '89 Mazda 323, next a '93 Nissan NX2000, and a '95 Civic Hatchback after that.....Even had a 2003 SVT Focus and '04 Ranger FX4 L2, wasn't until I had '16 Cadillac ATS-V that manufacturers starting requiring tools to remove and replace the engine air-filter, they used to just put metal flaps that you could flip over and flip back.
I think these greedy manufacturers think that if they make it some effort and have to grab a tool to change something as simple as an air filter, that people will just take it to the dealer. Same goes for the location for the oil filter.
  • Like
Reactions: jon
Tex
Cliff
San Angelo
Nothing yet but I was thinking about making one since mine is a Surf Fishing/Beach/Dirt Backroads Bronco.
I am also considering getting the K&N Performance Air Intake to replace the OEM box.
Hey, good luck with your K&N. I suggest running an outerwears and a foam prefilter between them at the very least if you're planning on taking it anywhere there's sand or dirt. The outerwears knocks out a lot of the larger particles but becomes very restrictive if it gets oily, hence the need for the foam prefilter, which doubles as a prefilter for the K&N. I was never able to get it up to adequate filtration standards, and it seemed like every weekend run or race I'd have to clean them all over again. Super restrictive when dirty, and as a result, if you keep running them dirty you'll get oily mud on your MAP sensor after your engine basically forces all that crud through the filter pleats. If I need to upgrade from OEM on any vehicle, a Walker Performance dry filter takes its place if at all possible.
Tex
Cliff
San Angelo
Don't most filters work better as they start to get dirty?
That depends on what you quantify better as. As a filter becomes laden with particulates, some of the larger holes become blocked, forcing air to take a more indirect path around and through the media, allowing smaller particulates to become trapped as well. In this way, a filter works a little better when it's a little dirty. The problem with that is you're getting more filtration at the cost of airflow. A dirty filter is worse in regard to engine power and efficiency, and you start taking a flow rate hit the moment it starts filtering out particulates. So the answer is yes and no, I suppose.
One caveat is that when your air filter is very dirty and laden with particulates, the force exerted by the engine intake on the media increases. Local air velocity through those tiny holes significantly increases and can lead to tears in the media, which end up being far larger than the mesh of the original and allows much larger particulates in. In extreme cases the pleats will give up entirely and you'll have a solid split right through your filter. So, a dirty filter will filter better...until it reaches a tipping point and lets a whole lot of crud through.
JaxGtc
Great video. The translucent box cover to show how the indent holds the filter was an amazing graphic - thanks for taking the time to add that bit of detail.
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
Thanks... The editing is a learning process. But it's great fun 👍🏻
The magnifying is a new trick for me as well.
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
I had a 2002 SVT Focus way back when...
In the process of converting it to a RS.
Ford Bronco Engine Air Filter replacement, maintenance and aftermarket filters (DIY video) AE00D8B3-BB60-4465-B32E-1557373EE894
l88m22vette
IL
Please sir may I have locking diffs?
I had a ZTS back in the day and installed a full SVT brake set. I also had an MTX75 with a Quaife I never installed, and even got an RS bumper shipped over from England, but it was trashed. Good luck with the RS conversion!
Gabby
Gabriella
Milwaukee
22' Bronco, 16 Tiger 800XCx, 96 Duc 900SS/Sp
Do you also use a prefilter?
I've used K&N forever on my bikes... But I don't think I'd do it with an offroader
I use a Uni Filter as a prefilter on my Tiger. But that's because the snorkle for the box was designed to let in sand, dirt, water, gnomes....
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
Damn gnomes anyways....
internationlriders
Josh
Alberta Canada
2021 Bronco Badlands
I keep a stack of paper OEM filters on my shelf, all it takes is a dusty road and your filter is needing a replacement. I had to replace my last one after only 5k miles roughly. As cool as K&N and other filter makers are, they are a big pain if you drive a lot of dusty roads, and the oiled ones clog up pretty fast in these environments.
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Nice vid :).
I had a K&N but out here in vegas it gets super dusty. A better paper one is more suitable for the conditions here. For the interior cabin filter I used IAG. Very nice and has active carbon in it too.
jon
Jonathan
UTAH
2003 Rubicon, 1989 Ford Bronco Eddie Bauer
You can also knock them off and use compressed air to clean them a couple of times.
internationlriders
Josh
Alberta Canada
Yeah I do this if I don't have a spare handy, but that super fine dust can still get in your engine, especially after you've been disturbing the dust by beating/blowing it out of the filter. Good stop gap measure though.
