Engine Block Heater Plug Location??
GiveItaTri
Robert
WI
F150, Big Bend
Does anyone have a picture of where the plug is located for the block heater? I know they usually come from behind the bumper, but I'm curious if that's true for the Bronco. Thanks
cigartexan
Jack
Boerne, Texas
1964 F100 SS - 2012 F-350 SD - 2021 4D Bronco FE
On every Ford that I've had with one, they're located tucked inside the driver side frame beam behind bumper.
flip
Phil
IN
www.ruxerparts.com
Fords
    • Remove and discard the bolt.
    • Separate the steering shaft and position aside.
Ford Bronco Engine Block Heater Plug Location?? video
Ford Bronco Engine Block Heater Plug Location?? Hel
  1. If equipped, disconnect the block heater wiring harness electrical connector and retainers.
  1. NOTE: Automatic transmission shown, manual transmission similar.
    • If equipped, disconnect the block heater wiring harness retainers from transmission.
    • If equipped, disconnect the block heater wiring harness retainer from the RH side transmission stud bolt.
  1. If equipped, disconnect the block heater wiring harness retainer from the RH side of engine block and position aside.
GiveItaTri
GiveItaTri
Robert
WI
F150, Big Bend
on my 2.3 it's underhood on passenger side inner fender.
Do you need to open the hood to reach the plug and use it?
FourHorses
Four Ford Horses and an Expedition
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I’m interested in installing this on my 2.3 MT as well…should be a relatively easy install?
GiveItaTri
GiveItaTri
Robert
WI
F150, Big Bend
I've been wanting to see a picture of the actual cord and plug, but I've had no luck.
jwoobs
Detroit
Mounted up inside the pass. side fender, right behind and above the headlight.
Standard 3-prong.
There is a rubber cap that is attached to protect the plug from spray and stuff. you can see it hanging down in this photo.
Ford Bronco Engine Block Heater Plug Location?? PXL_20211021_123927812
GiveItaTri
GiveItaTri
Robert
WI
F150, Big Bend
Standard 3-prong.
Thank you!!! I have to say, I hate that location. I live in northern Wisconsin and will be plugging in my Bronco for 4-5 months each year. Having to open the hood seems so inconvenient. Thanks, again.
FourHorses
I think that placement has made me decide to take it off of my build. I'm not opening my hood to plug that thing in all of the time.
Thanks for the photo @jwoobs!
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
Standard 3-prong.
Cool will ot work on 110/20v?
Seems like tje owners manual says 220/30v confusing
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
