- Joined
- Nov 24, 2019
- Threads
- 184
- Messages
- 2,152
- Reaction score
- 4,069
- Location
- Kirkland, WA
- Vehicle(s)
- FJ Cruiser
- Your Bronco Model
- First Edition
I by the running hard thing.. Get into the boat outboard field and the biggest killer is not getting them hot enough/running them hard. motors that get used and run close to WOT for a bit every time out last FAR those that idle/lug around all day.I’ve driven DOZENS of trucks very hard and heavily loaded over the years probably 2 million plus miles. I’m a Field service heavy equipment machanic with over 30 years experience.
Things I hear over and over but have never experienced In my life are the following..
The mythical “crappy oil”. Been using Dino oil out of drums, what ever is available at the shop. Never had an engine failure due to oil.
Crappy filters. Have used Napa. Donaldson, Baldwin etc. whatever the current employer buys for oil filters.. Never an oil filter related failure.
Only “AIR” filter EVER to cause a problem was a religiously cleaned and serviced K&N filter. Total crap. Gummed up a throttle body and intake. K&N is total garbage and let’s too much road grime in. Ran one on a 1997 454V8 3500HD for 89k miles and it made a mess of my intake before I realized it was the problem.
Not running hard enough? Never heard that one before.
my biggest pet peave is when somebody blames “crappy fuel”.
I would really like to know where one finds crappy fuel?
I’ve ran Only 87 octane fuel in anything that only required 87 octane fuel and have never had a fuel related issue other than maybe a dozen or so fuel pumps in mostly chevys.
Did I only run crappy fuel in my chevys and not in the Fords and Dodges? Nope. Same fuel. Chevys just had inferior fuel pumps plain and simple.
On the other hand. At Job sites, crappy fuel issues are real! Guys on job sites reuse 5 gallon jugs, buckets, barrels etc.. they have missing vent caps, fuel caps, dirty funnels you name it. Job site dust gets in the containers as well as rain water. I see crappy fuel issues on job sites constantly.. clogged filters full of dirt, clogged pick up tubes with leafs or bugs, water separators full of water etc... I have NEVER seen a crappy fuel issue from a vehicle that gets its fuel straight from a gas station pump.
I have no personal experience with the 3.5 and as a matter of fact, never even drove one before. What I do know is that If the 3.5 is so sensitive to these factors yet no other engine is, maybe the 3.5 is the problem. It’s always easier to chalk some issues up to “operator error” But if the problem persists with one engine and not “one person” it seems to me the blame should be pointed elsewhere.
