Maybe I am missing something, but I don't follow what you mean by no success correcting a low signal to the rear? I agree that trying to use forscan to "open" or "get a full range to the rears" is not a great solution and probably a waste of time if you are trying to build a complete system.Good product but you are just throwing money away if you can't put more power to the rear.
Combing through most of the threads over several months...no one (including myself) has with 100% success corrected (with forscan or an inline amp) the low signal to the rear to say match what the front is putting out.....until then, this is just a 6.5 that barely whispers in your ear...
Perhaps only the ford soundbar flash works as that is the only thing I haven't been able to test....
However, adding an amp that receives a full range signal (especially if you include a DSP) should allow you to do whatever you want with levels anywhere, front, rear or sub.
https://www.bronco6g.com/forum/thre...-and-sub-lots-of-pictures.43856/#post-1398035
