Sorry, I did a really bad job explaining it. RTI is ramp travel index. The ramp travel is the obvious part - i.e. you drive a single tire up a ramp, usually 20 degrees until the opposite side rear tire is in free air - and the index is a way to convert the distance traveled up the ramp into a usable metric of comparison. The formula for a 20 degree ramp is RTI = (distance / wheelbase) x 1000. The 1000 is there just to turn the ratio into an impressive sounding number. The important thing here for our discussion is the wheelbase issue.Yeah, I don’t really get the concept of this RTI formula and the resulting number (higher is better) conveying capability, at least in certain situations. The Longer wheelbase will go up the ramp further. Maybe I’m missing something. I was actually referring to suspension travel/flex.
By “flex balance” I’m guessing you’re referring to counterweight/transition speed of weight transfer? IE, teetering on rocks and drops/rises would be more aggressive in a short wheelbase.
the longer the wheelbase the less affected the rear axle is affected by the steep climb on the front axle. short wheelbase will require the rear axle to articulate further faster. That's what's meant by longer up the ramp. you could take a school bus to the top of a 20 degree ramp before the rear tire found free air. conversely, a short wheelbase will activate the rear axle far sooner and more extreme. That's why the wheelbase is considered, so vehicles of different wheelbases can be compared accurately (or accurate enough).
Flex balance is the amount of flex in the front compared to the rear. if the rear is very flexible but the front isn't than as the front wheel goes up the ramp its going to rely more on the rear axle to prevent a rear wheel lift. the longer the wheelbase the more the rear axle can play a role. Even if its not reflected in the actual number the actual distance up the ramp will almost always be further with a long wheelbase. i.e. the 4 door has a worse ramp score than the 2 door, but the 4 door will travel further up the ramp.
The Bronco has the same trouble as my land cruiser, where the rear is crazy flexible but the front is only so/so. In some situations thats enough, in others it leaves a little lacking.
here is a video showing what I mean. you can see how much harder the rear is working than the front. if the front was more balanced to the rear you would need less in the rear for the same effect
