Bronco4lyfe85
William
2019 Challenger Scat Pack
I like Bilstein suspensions.
dgorsett
colorado
F250, Mustang, Explorer
There has been much debate about suspension lift with various trims and Sasquatch Package. 10mm to 1.5" to 3" have been mentioned. I did a little analysis of overall height OAH vs tire size to come up with some answers using the Base as a baseline:
Base: OAH=71.9, Diff=0, Due to tire (30")=0, Due to Suspension=0
BB, OBX, BD: OAH=72.9, Diff=1, Due to tire (32")=1, Due to Suspension=0
Non Sas BL: OAH=73.8, Diff=1.9, Due to tire (32.7")=1.35, Due to Suspension=0.55
All Sas: OAH=75.2, Diff=3.3, Due to tire (34.4")=2.2, Due to Suspension=1.10
So my napkin math says BL gets, .55" Suspension lift and Sas gets 1.1" . This gives credence to the rumor there are three suspensions Base (Base, BB, OBX and BD), Badlands non Sas and Sas
Advertisement
MadMac
Mustang GT
I believe only difference between badlands and Sasquatch is tire size. Suspension should be identical. Tire size alone would only result in a 1 inch ride height increase.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
5280Bronco
Denver
Looks like all the same hard points on the bottom, just different coilovers. I take that as a positive.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
So, I am not seeing 3” of suspension lift looking at the axle compared to the pan hard bar mount. The photo angles are different but the axle may be an inch lowered relative to the mount in the Bilstein shot, certainly not three though. Only thing I don’t know is if that Bilstein one is a Sasquatch with 315 MTs or a Badlands with 285 MTs.
Either way, the 3” stated yesterday has to include increase in tire radius based on these pics.
JaxGtc
Would the OBX be slightly higher due to the 18" wheel? Maybe splitting the BB/BD and BL tire difference?
Advertisement
dgorsett
colorado
I used to think that too, but the difference is 1.5" so I'm beginning to believe there is a suspension difference, which might also explain the 10mm travel limitation on the Sas.
Merc4x4
steve
NYC
In one of the sema vids (I think) the Ford guy said they were similar, but different part numbers, so not identical.
dgorsett
colorado
No, the BB is a 255/75x17, the OBX is 255/70x18. The difference in aspect ratio 75 vs 70, makes up for the wheel size difference.
Merc4x4
steve
NYC
no, only radius of tire will change overall height (when solving for only tire diameter change)
North7
North Texas
Non-Ford
I saw this post right when it went up, I refrained from posting the popcorn, the number one subject that has never been discussed, has never had detailed calculations applied and has never come up with any answer other than...
We don't know and will not know until Broncos and parts are available for measurement.
Advertisement
