- First Name
- Brian
- Joined
- Jul 2, 2020
- Threads
- 6
- Messages
- 45
- Reaction score
- 39
- Location
- Charleston, SC
- Vehicle(s)
- 24 Bronco Wildtrak 4dr
- Your Bronco Model
- Wildtrak
- Thread starter
- #1
I received my EZ Trunk Monday evening and installed it in my 2024 Wildtrak 4dr soft top. The trunk came in two boxes and was well packed. No scratches or damage. Installation was simple and straightforward. The included instructions and video links show installation on a hard top Bronco. For the soft top, the supplied soft top brackets are used towards the front instead of the brackets that clip under the tub rail (see photo #5). Once the side panels are in, the center section is put into position and unfolded. You center this section and then bolt down the bottom brackets to the floor of the Bronco using one bolt hole from each of the four tie down points. At this point the install is complete. The unit fits perfectly. All edges have molding to prevent scaring up your interior trim. The top can be folded down to get larger items in the cargo area without the need of removing it from the vehicle.
Very happy with this product. At less than half the price of the Diabolical slipstream, you can’t go wrong with this security enclosure. Ken from EZ 4x4 was great to work with. He’s going to send me a promo code to share with the group. When I get it I’ll post it on this thread.
Updated!!!!
Just got a text from Ken at EZ 4x4. For forum members, 15% off with the discount code is EZFM15. This is good until the end of March 2025.
Updated!!!!
