Absolutely they will fit and look better too!Do you guys think it will fit 37x12.5x17 tires using the Sasquatch wheels? I just installed, looks like there is enough clearance. tires look almost too small now.
Did front level out? Measurements?Nitto Recons are on with Fabtech 1.5” level.
To the eyes yes. I haven't measure though.Did front level out? Measurements?
Did you ever measure? I’m looking to get the fab tech 1.5 for my SASTo the eyes yes. I haven't measure though.
Mine was perfect with non-sas and the Fabtech.Did you ever measure? I’m looking to get the fab tech 1.5 for my SAS
Mine went up 1.5" as it was supposed to. I also added .5" left to the rear. Total I have 3/4" of rake.Did you ever measure? I’m looking to get the fab tech 1.5 for my SAS
Hey there, what lift did you add in the back for .5in of lift? I need to do the same. Thanks!Mine went up 1.5" as it was supposed to. I also added .5" left to the rear. Total I have 3/4" of rake.
I used the top spacers from the Rough Country 1" leveling kit. The strut top hat is the same on the rear as the front, so any of the level kit spacers should work.Hey there, what lift did you add in the back for .5in of lift? I need to do the same. Thanks!
What size tire?Mine was perfect with non-sas and the Fabtech.
35x12.5x18 Yoko's -12 backspacingWhat size tire?
Looks great. I just got the fab tech on Friday. Did you have to remove anything for the 35s?35x12.5x18 Yoko's -12 backspacing
Just the crash bars.Looks great. I just got the fab tech on Friday. Did you have to remove anything for the 35s?
