Ok guys, I hava badlands squatch Lux so I have the wiring harness for front fogs I am assuming that is what this photo shows. I replaced my factory headlight switch to one that includes fog light button which entailed ordering one of the switches that is in stock without the puddle lights and taking the puddle light module from original and adding it to switch with fog light (as someone else her showed us could be done). Puddle lights are working with the new switch for what it is worth. Next I went in to forscan and changed the BdyCM and IPC as instructed here to activate switch which included changing Some people f the coding in the BdyCM as built configuration. I am getting the fog light indicator to show up on the display but I am not getting any power to the plug. Has Anyone else run in to this problem? I am in my shop with no access to a computer. I can check forscan when I get back home but thought I would ask for any other ideas first. You should know I have 0 experience with electrical wiring or forescan. I would not have even attempted to do the fog light switch/ forrscan changes if not for this forum. So thanks in advance for any help
Make sure you follow the following to a T. Toward the end is a paragraph with some very critical information regarding 726-42-01 for activating the harness circuit.
I've been trying to find time to tackle this for everyone and finally did. I hope this can serve as the base of a write up for everyone, I don't have much experience making write ups but I will try my best.
To enable and utilize the factory fog light harness these are the steps needed. You will need ForScan (obviously but had to clarify) and the headlight switch of your choice, mine specifically is the auto lamp one with spot light buttons and just the single fog light in the center of the dial (I forget the part number if anyone knows)
Connect to the vehicle and go into configurations --> BdyCM and open it.
You will want to find and change the following:
Front fog lamps - change this from "Disabled" to "Enabled".
Fog Lamp Switch - change this to "Enabled"
Using Front Fog With High Beam - This is an optional change but if you want to use fogs with high beams change it to "Allowed"
Write the settings made, you are finished with the BdyCM for now
Next you need to open the IPC which will turn on the fog light indicator in your gauge screen:
Front fog lamps - change this to "Enabled"
Write this setting and now we will go onto the As-Built change.
You will need to open BdyCM (As-Built Configuration). BACK UP THIS FILE in case anything goes wrong you can restore the original.
Locate the following line:
726-42-01-xxxx-xxxx-xxxx (My Badlands specifically was 726-42-01-0000-0000-0575)
You will need to change the second box to 0101. ForScan does autochecksum calculations so what I ended up with was 726-42-01-0000-0101-0577
Write this change
I originally started with just the first two parts but while the indicator would show up on the dash I was not getting power to the fog light harness in the bumper. I was curious and compared to a 2021 F-150 spreadsheet. This 726-42-01 is the control line for what the Left and Right fog light circuit actually does. There's a few options but the default setting is "not used". The setting I changed it to (01) is "Fog cornering" (I assume 04 for Fog Only will work too) but there is another one (05) which basically turns that circuit into an always on 12v. The switch does not turn it off and while I tested it with the vehicle on I forgot to check it with the vehicle keyed off though I assume it would be a key on only setting. I mention this just because it could be useful to somone here who may not be hooking up fog lights but might want a low amp, I believe the fuse is only 5 amps, source for other accessories.
For those curious here is the full list of options but I only tried the two I mentioned:
LF_Fog_Lamp_Ckt_Usage_Cfg: 00=Not Used 01=Fog Cornering 02=Fog DRL 03=Fog DRL Cornering 04=Fog Only 05=Power Supply
Also, I did not research or attempt anything relating to the Rear Fog Lamps. I know some people here are seeking that but unfortunately I didn't dive into that yet.
