Thanks grant. Happy holidays
Isn't this what we want, the ebb turned off?Nothing new in the TSB list.
Paper manuals do not have that statement.
Thought so.“Note: Electronic brake booster deactivates when neutral tow is enabled. Braking light does not respond when the feature is enabled.”
Is that new?
Mine and a whole lot of other permanent brake system will not work if the EBB is turned off.
They require brake boost to be on to get full braking force.
That's what the auxiliary vacuum pump took care of on the systems with vacuum boost.
[/QUOTE are you using the Readybrake
Assuming that EBB is turned off, which brake systems work, and which ones don't?Mine and a whole lot of other permanent brake system will not work if the EBB is turned off.
The easy answer is any system that can apply enough force on the brake petal to stop the vehicle without any kind of brake boost.Assuming that EBB is turned off, which brake systems work, and which ones don't?
I contacted Demco yesterday, they told me that the Demco Stay-IN-Play DUO will work with the 2.7 with EBB disabled.Assuming that EBB is turned off, which brake systems work, and which ones don't?
