- Delynn
- Jul 15, 2023
- 0
- 10
- 8
- Somerset, KY
- Bronco Outerbanks and Bronco Wildtrak
- Outer Banks
I had the same thing happen as you. When stopped at campground on 3rd stop it would not disengage neutral tow. I went over it with my dealer and went through all the same troubleshooting steps you did. After no positive result they said tow it back home. When we got back and dropped it off at my home dealership they found out it was the transfer case motor that went bad and would not disengage the neutral tow. They changed the motor out in less than 1 hour and it worked as advertised with no further problems. I am just curious, we’re you given the opportunity to be able to visualize the damage to the transmission and transfer case?No, it doesn't. I have my own thread on this, and so many people on here are certain there was a mistake made by the owners...I did the procedure absolutely correct, had the wife verify tires were rolling at each and every stop. Arrived and the stupid thing was stuck in neutral tow.
Dealer took nearly a month to fix it, had to replace transmission, transfer case, and the transfer case motor. Could not tell me why it self destructed, nor could pull any computer data to prove/disprove it being put in neutral tow. I thank God that it was stuck in neutral tow. I lost my ass trading it in after that, but I'm back in a Jeep and again have zero issues flat towing. You're rolling the dice every time you flat tow an automatic Bronco.
