Ford Bronco vs Jeep Wrangler: A Full Comparison including Trim Breakdowns!
FirstOnRaceDay
Moderator
Staff member
Moderator
Devin
Toledo Ohio
00 Grand Marquis,17 Civic, 19.5 Silverado
Vehicle Showcase
So I did a full technical Breakdown of the Bronco vs Wrangler
will be doing a trim by trim and option vs option break down soon
SIZE
POWERTRAIN
DYNOGRAPHS
CAPABILITY
INTERIOR
FULL TRIM COMPARISON AND BREAKDOWN
(Still Working)
Bronco Base = Wrangler Sport (Basic)
Bronco Big Bend = Wrangler Sport S (Basic + options)
Bronco Black Diamond = Willys (Light offorader)
Bronco Outer Banks = Wrangler Sahara (Mall Crawler)
Bronco Badlands = Wrangler Rubicon (Rock Crawler)
Bronco Wild Track = Mojave (Baja)
Advertisement
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
Yep, making the right choice here
Also, regardless of engine, makes more power much more easily than the Jeep, though to be fair, they didn't really have any real competition until now, so they gotta address that
FirstOnRaceDay
FirstOnRaceDay
Moderator
Staff member
Moderator
Devin
Toledo Ohio
Vehicle Showcase
TBH, I don't know much about the 2.7L EB specs but I love the shape of that torque curve for a fairly heavy truck. It must have some smaller turbos to get spooled up like that just off idle.
Only 17-19psi in the Nano engine.
lobbs611
Kyle
Independence, MO
19 Cherokee Trailhawk
Yeah, I'm totally fine with that for this application. I'd rather have something that spools up more quickly lower in the power band. You can see over about 3500 rpm they may become a slight restriction. But this is a truck not a sports car. Bigger turbos would give you more up top but at the risk of softening up the low end response.
FirstOnRaceDay
FirstOnRaceDay
Moderator
Staff member
Moderator
Devin
Toledo Ohio
Vehicle Showcase
And I think that’s why the Bronco has the lowest HP out of any other 2.7 in fords lineup. All low end torque. Small turbo.
you only need that top end torque for 60-120mph. And this is a off road truck. Not a sports car. You don’t need That top end.
Laminar
Iowa
Cougar
Where'd you find curb weight specs?
Laminar
Iowa
Cougar
Should probably have an asterisk then, no? If it's longer, wider, taller, with turbos, and bigger wheels/tires how could it not weigh more?
FirstOnRaceDay
FirstOnRaceDay
Moderator
Staff member
Moderator
Devin
Toledo Ohio
Vehicle Showcase
most of the numbers for the bronco are either “targeted” or “est”
the ones with the asterisk are completely unknown.
Rogues Gambit
Eatontown, NJ
Hijacking for a second, but how's this (4dr) compare to the Edge size wise.
Fords sites being all wonky still and Office Manager's kinda on the fence, as he wants to see it in person
Advertisement
BDS Suspension
Advertisement
