Ford Bronco vs Jeep Wrangler: A Full Comparison including Trim Breakdowns!
FirstOnRaceDay
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
Hijacking for a second, but how's this (4dr) compare to the Edge size wise.
Fords sites being all wonky still and Office Manager's kinda on the fence, as he wants to see it in person
Bronco 4 door base vs Edge SE
WB - 116 vs 112
L - 189 vs 189
W - 76 vs 76
H - 73 vs 69
Lbs 4400 vs 4200
1 head - 41 vs 40
1 leg - 43 vs 43
1 shoulder - 57 vs 60
1 hip - 56 vs 56
2 head - 40 vs 40
2 leg - 36 vs 41
2 shoulder 57 vs 60
2 hip 55 vs 57
passenger volume 104vs 114
Cargo 36 vs 40
Very similar in size
The bronco sits higher and had slightly less rear seat space and cargo. Probably not very noticeable.
hence why I think the Edge is on the way out
Chcg12
chicago
2020 Gladiator
As good a place as any to ask this
; The bd and badlands are the only models with rubber flooring and drain plugs. The wrangler has drain plugs regardless of model. Do we think all broncos have drain plugs under carpet? that way you could remove carpet and line x the floors or get aftermarket rubber flooring..thought? Thanks
EvlNvrDys
Hunterdon County, NJ
Hell if they don't, you can always remove the carpet, drill a few holes and put your own rubber plugs in there.
As far as Ford doing it in all models, I haven't the slightest. They make it sound like they all don't.
And furthermore, Jeep needs plugs in all Wranglers because that crap they call a hard top leaks like a sieve. Wife's Jeep always has wet carpets after a heavy downpour.
FirstOnRaceDay
FirstOnRaceDay
Devin
Toledo Ohio
ADDED TRIM BREAKDOWN
Updated to include mechanical options
working on
appearance
Interior
And tech
impulse
South Alabama
Ford Escape, F-150
WB - 116 vs 112
L - 189 vs 189
W - 76 vs 76
H - 73 vs 69
Lbs 4400 vs 4200
1 head - 41 vs 40
1 leg - 43 vs 43
1 hip - 56 vs 56
2 head - 40 vs 40
2 leg - 36 vs 41
2 shoulder 57 vs 60
2 hip 55 vs 57
Cargo 36 vs 40
Ford trainer told us that new Ford Edge is being worked on right now. Really it should have come out this year. Edge is now the oldest car Ford makes that doesn't have an update. Everything else is being cut or updated.
North7
North Texas
SUV
So I did a full technical Breakdown of the Bronco vs Wrangler
will be doing a trim by trim and option vs option break down soon
Hi @FirstOnRaceDay, great job, thank you. When you have time can you please do a little further breakout on the Max Price. The Jeep Max Price you show of $42,500 seems to be for the for the Rubicon but Jeeps Max Price model is the "High Altitude" model at $49,995.
Otherwise the guys from the Jeep forums will latch onto this thread and say, see, the Bronco is more expensive, without comparing apple to apple, feature to feature, model to model.
FirstOnRaceDay
FirstOnRaceDay
Devin
Toledo Ohio
Working on that still but 100%
want to add interior and tech packages too.
you get so Much more standard on bronco.
Laminar
Iowa
Cougar
2 leg - 36 vs 41
The rear legroom is suuuuuuuuuuper noticeable. You're not comfortably fitting a rear-facing seat in a Bronco. On an Escape it's tight. On an Edge it's a piece of cake. Some people don't want to have to deal with the 3 rows on the Explorer.
Given that Ford ditched all of its cars and is trying to emulate the success of Subaru and Jeep with "capable" vehicles, I doubt they're going to ditch something selling more than 100,000 units/year when they no longer have any cars to compete.
FirstOnRaceDay
FirstOnRaceDay
Devin
Toledo Ohio
Keep in mind the front leg room is better on Bronco than Edge 43vs 41.
So that’s only 2” different.
also I agree with you. However ford has made 0 plans. It’s their oldest vehicle at this point. Ranger and Transit are getting updates next year. After that it’s only Edge that hasn’t been updated.
it wouldnt take them long however. Simply stretch the Escape longer. 2.0 base engine 2.3 ST. Done.
We should Find out soon since Canada’s Union is negotiating the Plants future.
Steeler412
2022 Black Diamond Manual Sas 2 Door, 2006 F150
@MightyAndrew, how do you think the cyber orange compares to the color rush jerseys shade of gold? I have a hard time with colors on TV vs in person
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
Yeah, I'm totally fine with that for this application. I'd rather have something that spools up more quickly lower in the power band. You can see over about 3500 rpm they may become a slight restriction. But this is a truck not a sports car. Bigger turbos would give you more up top but at the risk of softening up the low end response.
This is gonna be my Daily/Week/Roadtripping until its too dead to fix up
So I don't mind how it is, by the time the original engine/Trans goes, they'll have Gojira Swaps with a Tremec anyway
tripjammer
tripjammer
2021 GR Supra 3.0 Premium
Since the 2.7 liter V6 comes with the 10 speed auto, there would not be a $2k charge for the 10 speed auto. Why would anybody who is going auto not get the $1500 2.7 liter V6? Ford only charges $995 for the 2.7 liter V6 on the F150 and it includes the 10 speed auto...so your prices maybe a bit off here.
FirstOnRaceDay
FirstOnRaceDay
Devin
Toledo Ohio
you have to pay for both. So 2.3 manual vs 2.7 auto is $3,500 difference.
I figured the bigger difference between the 2.3 vs 3.3 is worth $500
could be wrong
Broncolli
MD
'21 Back Diamond 4 door MIC
Wrangler Willys = Bronco Black Diamond
Wrangler Mojave = Bronco Wildtrak
