shoelessjoe
2013 Chevy Cruze
You could add. Use the part itself for a mounting template then PRECISELY drill and place rivnuts through the existing metal bar. Not a huge project, but might need to rent a hydraulic rivnut setter.
Same for the OP if one hole doesn't have threads of they are damaged. Drill it out carefully and install a new rivnut.
No. It help the chassis resist large loads from terrain.
Better buy a few dozen carbide drill bits. Drilling into the roll bars ain't easy.
vrtical
Doug
GSMNP, TN
Fords
I got one of those and welcome to the braptor tax where every part is tripple cost for no reason.
mpeugeot
It could be made of the same steel as the roll cage, which might explain some of the cost, but certainly not all of it.
ScLeCo
Springfield
Charger Hellcat
Sounds like the Hellcat tax where 80% of the parts are the same as a V6 rental car but are triple the cost and have a different part number for the exact same part for some reason.
BigMeatsBronco
Allan
2021 FE 2 door
This is the last thing I would ever buy....I mean the Braptor towing brace makes sense....but this is a complete joke. no reason use this at all with stock suspension!!!
the ugly freaking fender flairs are a better addition than this doodad
So the frame is tougher now but the spare tire will still destroy the rear gate at Braptor speeds Going Over Any Terrain that will test the new doodad...
why not add the Braptor rear gate HD parts instead, at least they are usefull...
Area51BS
Ron
Badlands non SAS 4dr 2.3
The Raptor doesn’t have that much more torque over 2.7. And the body is rubber mounted/isolated from the frame which the motor sits in. So body twist is somewhat isolated from motor torque. I think it’s just something that sets the Raptor apart. JMO.
Silver-Bolt
Bill
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
Out of curiosity, has anyone twisted their frame from not having this?
I've bought some stupid crap before but this seems like a total waist of a 1000 bucks.
It has zero to do with stiffening the frame. The Bronco is a body on frame. The body mounts are rubber. The brace might help to stiffen the body/tub in the event of a roll over. It has nothing to do with the chassis.
vrtical
Doug
GSMNP, TN
Fords
This is from Ford don't shoot the messenger, but yes its more body related than obviously connected to the frame with rubber.
B-pillar cross bar and C-pillar reinforcement help deliver a greater than 50% total body-in-prime torsional rigidity increase over a standard Bronco four-door model
Silver-Bolt
Bill
This is an accurate statement. 50% BODY rigidity, not chassis.
Compta38
Alabama
Ford Fusion
We have two extra braces for structural rigidity. I forget the % but its pretty significant.
thanks. I guess it works like the braces folks used to put in their f-body cars under the hood back in my car days. I don't see a grand for that piece of metal so I'll wait for Mabetts better version that costs a quarter of it and comes with 15% off coupon.
35tires
'23 Bronco, '21 4Runner
I was hoping for something that decreased rear view visibility a bit more.
People will buy ANYTHING.
I’m just looking for my “in” for my quick buck modification no one needs. Maybe led roll bar bolts.
