Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
CliffCo
Cliff
Charlotte
2021 Iconic Silver, Big Bend Sasquatch (MIC top)
Wish I could add that to my ‘21 but mine was one of the builds that doesn’t have the threads holes on the back side of the roll bar.
Mine too... :cry:
I saw one in person and it looks AWESOME
Peteduce
Bay Area
18 ND
Do you feel any difference in driving characteristics, and NVH? I know adding a cross cross bar and a roll bar makes a significant difference on a miata. But it's a small tin can car compared to the bronco. If this solves the creaks on driving on washboard or rough roads. It's not a bad idea to add one.
FreddieLee
Freddie
How much lift is on the Everglades?
buck_6G
Austin, TX
Toyota Tacoma TRD Pro
Looks cool. Is it an aesthetic choice or are you anticipating a lot of impacts at higher-speed that might deform the roll cage?
swamp2
You could add. Use the part itself for a mounting template then PRECISELY drill and place rivnuts through the existing metal bar. Not a huge project, but might need to rent a hydraulic rivnut setter.
Same for the OP if one hole doesn't have threads of they are damaged. Drill it out carefully and install a new rivnut.
They keep the frame from twisting under the Raptor torque load.
No. It help the chassis resist large loads from terrain.
Cop0251
Cop0251
Chad
Cayce
I keep the top off a lot and it helps a little with the top shake over bumps plus I think it looks really cool. May end up getting the center cross brace for the top as well from the raptor or the other one on a different thread here.
Compta38
Alabama
Ford Fusion
I don't understand the point of this part at all.
