BigFootie
Wisconsin
2013 ES-350, 2022 Badlands Sport, 2023 Heritage Ed
I also installed my own 7-pin setup and brake controller. What did you have to use forscan for?
Having it allow sway control and disabling blis when your trailer is hooked up I believe.
Beach_Bum
St. Augustine, FL
Finally had the wiring harness/programming completed today. Dealer called this morning (appointment was yesterday) saying it was done. I asked a few questions leading to the FDRS programming. He said there was none. They were going to try and get by with just running the wiring. I referred to the last page of the instructions where it references Tow Bar Configuration in FDRS. He quickly dismissed my concern. I then indicated that I'll check when it is dropped off and if it wasn't enabled that they could drive it back and fix it. 4 hours later, the valet called to drop off my Bronco.
Makes me think that they had only installed 4-pin harnesses before and hadn't had experience with the 7-pin kit.
HopeHawk76
Cypress, TX
Honda CRV
Got notification from Ford that the OEM hitch assembly was back in stock so I ordered mine with the 4/7 wiring harness in December. Scheduled for installation at a local dealer here in Houston this week. Fingers crossed that it goes well...
F-Spot
SoCal
Tesla, FJ
Finally got my 7-pin installed yesterday by Gosch Temecula. It took the whole morning, but they said the install was smooth and no issues with FDRS. They did install the wiring plate to the backside of my Curt Hitch with just the outside hitch mounting bolt. I believe there is enough slack in the wiring for me to move it to the front.
When looking at the tow screen, I’m only seeing the “Trailer Sway Control”, whereas others in this thread also have “Trailer Light Check”. Do I need to use FORSCAN, or does that only show up after adding a trailer brake controller?
Ford Bronco Ford Releases 7 Pin Tow Wiring for Factory Installation IMG_2884
KenDawg78
Lakeside
Nissan Pathfinder
To setup sway control and disable blis during tow
I just had my car in the dealership, if you add an aftermarket 7 pin and did not have factory wiring you can't add the factory functions.
Zakm
Zakm
Zak
Jacksonville, AR
That's odd that they said that, because I did. I bought the trailer module(which is what makes it work with forscan) and the rest was aftermarket wiring and 7 pin harness. I use to work at Ford as a technician and most of them don't dive deep into specific vehicles.
MHRider06
SC
2019 Ranger XLT
How do I know that the dealer has configuration on my Bronco after I installed the Lumen 4/7 wiring harness kit through Ford Accessories?
TheKim
Kim
Got my dealer to install the 4/7 pin harness and hitch from the parts catalog. Looking forward to getting out there with this thing.
Ford Bronco Ford Releases 7 Pin Tow Wiring for Factory Installation 1706125131209
TheKim
Kim
sundaeman
Joel
MD
Dealer just called and said they need the Bronco for another day to install the kit. More complicated than they thought and the service writer thinks they've only done one before. They thought it was going to be like a 4 wire.
Can't wait to have them hit me up for extra cash when I pick it up. :(
They did not hit me up for extra cash. I was pleasantly suprised.
Mr Toad
Ben
Pacific Northwest
2023 Bronco Badlands Sasquatch 2dr
So pretty much 7 pin for $425 with installation included. Kind of difficult to justify price difference for 4 pin I got from Curt for $55...
If you ever have to tow a boat trailer with hydraulic disk surge brakes, you won't be able to do it with your 4 pin set up. You need a reverse signal to operate the lock out solenoid so you can back down the boat ramp. You can tap into the reverse lamp wire behind one of the tail lights and run your own wire, but it is much more convenient to use a 7pin to 5 pin adapter when needed. If you ever have to tow something with electric brakes, you'll also need the 7 pin set up.
Gabby
Gabriella
Milwaukee
22' Bronco, 16 Tiger 800XCx, 96 Duc 900SS/Sp
I ordered and installed the Broaddicts hitch myself, simple, took about 30 minutes. Ordered the Ford Accessories 7 /4 pin harness from Ford and paid for the install fee of $120.00 at the same time. My Ford dealer had the Bronco for two and a half days, I don’t how much time they actually worked on it. I got a call at the end of the second day that the harness was causing faults, but it would be ready the next day. When I picked up the Bronco they tried to charge me $487.00, I had to explain to them that I had pre paid the installation and still got a call at home an hour later about paying the bill. I think the $120.00 was a good decision for me.
See, this is my fear. My dealer already has a habit of trying to charge me for my prepaid maintenance.
