FORScan codes to disable the factory LUX wireless charger
KurtHu
Kurt
Seattle
2023 Azure Grey Wildtrak 4dr, 2014 Black JKURX
I'm getting ready to remove the factory wireless charger. Does anyone know of the FORScan codes to disable it. Hoping to avoid any DTCs once I remove it. Thanks!
KurtHu
KurtHu
Kurt
Seattle
I just replaced mine with an aftermarket one and it seems to work pretty well.
Thanks! Was it plug and play? Do you recall the maker of the aftermarket replacement? Sounds like it works better than the factory one.
Strizzo
Bryan
Houston, Tx
Lexus GX460, 1966 Mustang Convertible
IAG sells one, I think its plug and play if you didn't have one also, so it probably won't throw any codes removing it. Is it that bad?
KurtHu
KurtHu
Kurt
Seattle
Just checking again to see if anyone has FORScan codes to disable to factory wireless charger. Thanks all!
KurtHu
KurtHu
Kurt
Seattle
